Algebra question - rings and ideals
  • Thread starter Thread starter quasar987
    Algebra Rings
quasar987
[SOLVED] Algebra question - rings and ideals
Let R be a (nonzero) commutative ring with identity and I be an ideal of I. Denote (I) the ideal of R[x] generated by I. The book says that (I) is the set of polynomials with coefficients in I. Why is that?
Call A the set of polynomials with coefficients in I.
R is commutative and so is R[x], therefor (I) is simply given by
(I) = {a*p(x): a is in I and p(x) in R[x]}
So clearly (I) is a subset of A.
But for the other inclusion, given b_0+...+b_nx^n in A, we need to find an element a in I and a set {a_0,...,a_n} in R such that a*a_i = b_i for all i=1,...,n.
How is this achieved??
If b_0+...+b_nx^n is in A, then b_0, ..., b_n are all in I, and thus in (I). The latter is an ideal, so b_kx^k is certainly in (I), and so is the sum of such things.
Edit:
I don't really see how this follows. I would instead prove that A is an ideal of R that contains I and hence contains (I) by definition.
Of course it does not follows! I was confused.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
