Algebra with a little differenentation
  • Thread starter Thread starter munkifisht
    Algebra
munkifisht
I have the following terms
X, Y, Z, J and K
Where everything is a function of t
I want to combine these equations into a single equation where the X, Y, and Z terms are no longer in the equation and there are only terms of J on the RHS and K on the LHS or visa versa
i) X = Y^2 + Y
ii) Z = dX/dt
iii) J = Z + Y
iv) K = X + J
I'm told this should be possible but not matter which way I combine these I get something along the lines of
K = J^2 + ( K'(t) + J'(t) )^2 - 2*J ( K'(t) + J'(t) ) - ( K'(t)+J'(t) )
and obviously this is going to leave you with products of J and Ks that can't be separated (I need all the K'(t) terms to be over with it's buddy on the LHS). No matter what stratagy I use to avoid this I can't help but get these terms combining.
munkifisht said:
I want to combine these equations into a single equation where the X, Y, and Z terms are no longer in the equation and there are only terms of J on the RHS and K on the LHS or visa versa...
Where did this problem arise?
I'm told this should be possible...
Who told you this is possible?
It's a simplification of an RCR electrical circiut problem with a variable resistor that varies as a function of the current. It was an assignment. I've asked and I know the first part is correct.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
