What is the Formula for Finding the Slope of a Tangent Line on a Curve?
  • Thread starter Lucretius
  • Tags
    Calculus
In summary, the conversation is about the topic of calculus and a specific problem involving finding the slope at any point on a given curve. The person who posted the initial problem encountered difficulty and received help from others in the form of suggestions and formulas to use. The conversation also delves into the topic of derivatives and limits, which the original poster plans to learn before revisiting the problem.
Lucretius
152
Well, seeing as I will be working on calculus for a long time, and I figure at the rate I've been going I'll get stuck a lot and need help, I'll just make one thread for all my calculus troubles.
I just read the chapter on Tangent Lines and Slopes. I did a problem, double-checked the math, then turned to the back of the book and found out the answer was completely incorrect. I retraced again, and found no problem, but the book is a bit confusing so I might have missed something.
The problem reads: Find a formula that gives the slope at any point P (x,y) on the given curve. [itex]y=4-x^2[/itex] [itex]P:(1,-1)[/itex]
My work is as follows:
1)I begin by making a secant line from point P to a point Q, which I arbitrarily place. The coordinates are [itex]Q:(-1+\Delta x, 4-(-1+\Delta x)^2[/itex]
2)To find my slope: [tex]\frac{\Delta y}{\Delta x} = \frac{4-(-1+\Delta x)^2}{\Delta x}[/tex]
3)This becomes: [tex]\frac{4-1+2\Delta x-\Delta x^2}{\Delta x}[/tex]
4)Finally, I get [itex]5-\Delta x=m[/itex] Getting rid of the [itex]\Delta x[/itex] my slope is [itex]m=5[/itex]
The back of the book says the answer is -2x.
What happened?
I'm new here, but I might be able to help.
Since you read the section on tangent lines, did you read about:
[tex]f'(x)=\lim_{h\to 0}\frac{f(x+h)-f(x)}{h}[/tex]?
Try using this formula on your original equation [tex]f(x)=4-x^2[/tex] and that will give you the tangent line at any point.
The section on limits and derivatives comes right after this one.
Hmmm, I don't understand what you are doing here...
P(1, -1) is not on the curve.
Let [itex]P(\varepsilon, 4 - \varepsilon ^ 2)[/itex]be a point on a curve.
Let [itex]Q(\varepsilon + \Delta x, 4 - (\varepsilon + \Delta x)^ 2)[/itex]be another point on a curve.
You have as [itex]\Delta x \rightarrow 0 => Q \rightarrow P[/itex]
Can you find [tex]\frac{Q_y - P_y}{Q_x - P_x}[/tex] as [tex]\Delta x \rightarrow 0[/tex]?
Er, I think limits should be learn before tangent line.
Viet Dao,
Should I skip past this chapter for now, learn limits, and then return to it?
You mentioned P(1,-1) is not on the curve — and you're right. It's (-1,3). The math I did uses (-1,3) though, I just mistyped it here.
Can you make that itexed slope formulation tex-ed? It's too small, can't read it.
Should I substitute 0 for [tex]\Delta x[/tex]?
What happened?
i don't know how far along you are, but all you need to do is find the derivative of the given function:
[tex]y=4-x^2[/tex] the derivative of this is -2x.
the derivative of a function is the slope of the tangent line at a certain point.
for the point (1,1) the equation of the tangent line is :
[tex]y-1=-2(x-1)[/tex]
I think the OP is just beginning with calculus and is not allowed to "just differentiate".
So, going back to first principles, the slope of a tangent to a curve at a point is defined by [tex]\frac{dy}{dx} = \lim_{\Delta x \rightarrow 0} \frac{\Delta y}{\Delta x}[/tex]
We have [tex]y = 4 - x^2[/tex]. ---eqn(1)
Then
[tex]y + \Delta y = 4 - (x + \Delta x)^2 = 4 - x^2 - 2x\Delta x - (\Delta x)^2[/tex] ---eqn(2)
using the binomial expansion.
Take eqn(2) - eqn(1),
we have [tex]\Delta y = -2x\Delta x - (\Delta x)^2[/tex]
Divide that by [tex]\Delta x[/tex],
[tex]\frac{\Delta y}{\Delta x} = -2x - \Delta x[/tex]
And taking the limit as [tex]\Delta x[/tex] goes to zero, we have :
[tex]\frac{dy}{dx} = -2x[/tex]
as we would expect. This is the equation that gives the slope of the tangent to the curve at any point (x,y)
If you want the equation of a line that has that slope and that passes through the point (1, -1), the equation of that line is simply,
[tex]y - (-1) = -2X(x - 1)[/tex]
or [tex]y = -(2X)x + 2X - 1[/tex]
Note that that line will NOT actually be a tangent to any point on the curve, it will only be parallel to the tangent to the curve at the chosen point [itex](X,Y)[/itex].
If you want the equation of the actual tangent line to the curve at a point [itex](X,Y)[/itex], then it would be given by
[tex]y - Y = -2X(x - X)[/tex]
[tex]y - (4 - X^2) = -2X(x - X)[/tex]
which rearranges to
[tex]y = -(2X)x + X^2 + 4[/tex]
It seems as if you are all suggesting that I use derivatives and/or limits. I believe I will skip this chapter, learn how to do limits and derivatives, and then return to it at a later time. Wish me luck with derivatives and limits. I will need it.
choose an arbitrary x
then the point P = (x, 4 - x^2) is on the curve
now move to another x a short distance Δx away: x + Δx
then the point Q = (x + Δx, 4 - (x + Δx)^2 ) is also on the curve
the slope of the line connecting P and Q is:
[tex] \mbox{slope \overline{PQ} } \ = \ \frac {\mbox{ (y value of Q) } \ - \ \mbox{ (y value of P) } } {\mbox{ (x value of Q) } \ - \ \mbox{ (x value of P) } } \ = \ \displaystyle \frac { ( 4 - (x + \Delta x)^2) \ - \ ( 4 - x^2 ) } { (x + \Delta x) \ - \ (x)} \ = \ \displaystyle \frac { - 2x\Delta x \ - \ (\Delta x)^2 } { \Delta x} \ = \ -2x \, - \, \Delta x [/tex]
now what happens to Δx when point P approaches point Q?
if you answered that Δx → 0, then what is the slope of the tangent to the curve?
1. What is "All my Calculus Troubles"?
"All my Calculus Troubles" is a comprehensive guide and resource for students struggling with calculus concepts. It covers topics such as derivatives, integrals, and applications of calculus.
2. Is this resource suitable for all levels of calculus?
Yes, "All my Calculus Troubles" is designed to help students at all levels of calculus, from introductory courses to advanced topics.
3. How is "All my Calculus Troubles" different from other calculus resources?
"All my Calculus Troubles" is unique in that it breaks down complex calculus concepts into easy-to-understand explanations and provides practice problems and step-by-step solutions for each topic. It also includes real-world applications to help students see the relevance of calculus in their everyday lives.
4. Can I access "All my Calculus Troubles" online?
Yes, "All my Calculus Troubles" is available as an online resource, making it easily accessible for students to use on their computers or mobile devices.
5. Are there any additional resources or support available with "All my Calculus Troubles"?
Yes, "All my Calculus Troubles" offers additional resources such as practice quizzes, study guides, and video tutorials to further aid students in their understanding of calculus. There is also an online forum where students can ask questions and receive help from other users and experts.
