Alternating Current Explained: How Does It Move Forward?
Alternating current (AC) differs from direct current (DC) in that the electric field in AC changes direction, causing electrons to oscillate back and forth rather than flow in a single direction. This oscillation allows AC to perform work in devices without the need for electrons to continuously move forward, as they are already present in the wire. The electric field, generated by voltage applied across the circuit, influences the movement of these free electrons in the copper wire. The key takeaway is that the movement of electrons, whether forward or oscillating, is what enables electrical work to be done. Understanding this concept clarifies how AC operates effectively in electrical systems.
PrincePhoenix
Can someone please explain how the current regularly changes direction after some time in alternating current? I mean if it changes direction, how does it move forward?
Hi there,
You have to understand that it is not necessarily a current like water flowing through a hose. In an electrical wire, the electrons are submitted to an electric field. In a DC current, the electric field is continous, and pushes the electron forward. But the electrons make direct hit with the atoms in the wire, therefore being constantly slowed down, to a few cm per hour.
In an AC current, the electric field changes direction constantly. The electrons present in your wire will therefore go back and forth, creating the current and the potential work done on the appliance. Therefore, you don't need it to move forward, since electrons are everywhere in the wire.
Hope this helps. Cheers
Can you explain it a little simpler? Which electric field are you talking about, that is continuous and pushes electrons forward in DC?
Hi there,
I'll try to give you simpler explanation.
To generate a current AC or DC, you need voltage. I'll keep with the copper wire example. A certain voltage is applied at both ends of your circuit. Voltage is just another way of saying that an electric field is created in the wire.
Remember that electrons, being electrically charged particles, will only react under the influence of an electric field.
Ok, so you have an electric field that forces your electrons to move. Fact is that the electrons in your wire are not coming from very far. They are taken right there on the spot, using the "free" electrons of copper atoms.
Now to make my story complete, it is the movement of electrons that will make the work in your device (mp3 player and so on). Therefore, whether the electrons are always pushed in the same direction, or whether they change direction, as long as they move.
Is this any clearer now?
Cheers
Yeah. That made it a lot clearer. Thanks
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
