Alternating Series Test for Convergence
thagzone
Does this series converge absolutely or conditionally?
Series from n=1 to ∞ (-1)^(n+1) * n!/2^n
In trying to apply the alternating series test, I have found the following:
1.) n!/2^n > 0 for n>0
2.) Next, in testing to see if n!/2^n is decreasing, I found that (n!/2^n)/((n+1)!/2^(n+1)) < 1 for n large.
Stopping here, this suggests the series diverges in its original form. Is this correct? Thank you!
You have apparently shown the terms of the series are increasing for n large, so they don't go to zero. So yes, you are correct that the series diverges.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
