Ampere's Law-cylindrical shell
  • Thread starter Thread starter Krikri
    Shell
The discussion focuses on calculating the magnetic field around a conducting cylindrical shell with a given volume current density. The user correctly identifies that the magnetic field is zero for r<R1 and derives the enclosed current for the region R1<r<R2. They detail their calculations using Ampere's Law, noting the magnetic field's behavior outside the cylinder decreases with a ratio of 1/r. There are some corrections made regarding integration and the evaluation of the magnetic field, but overall, the user's approach is validated. The conversation concludes with acknowledgment of the assistance provided in clarifying the calculations.
Krikri
A conducting cylindrical shell has it's axle on Ox axis, inner radius R1 and outer radius R2. If the volume current density is given by the formula \vec{j}(r)=J0\frac{r}{R1}\hat{i} where J0 is a constant and r the distance from the cylinder's axle, calculate the magnetic field \vec{B} : 1) Everywhere in space and 2) On the Oy. Oz axis in a position y>R2 and z>R2
Using ampere's law we can easy say that for r<R1 the magnetic field is zero because there is no current passing through the amperian loop. For R1<r<R2 the region that the not uniform density takes place.
I draw an amperian loop of radius r. The whole point as i see it is to calculate the Ienc . So step by step what i did :
1) dI=J*da ,da=2πrdr so dI= \frac{2π}{R1}j0 r2dr
2)so Ienc= \frac{2π}{R1}j0 ∫r2dr from R1 to r.
3)so Ienc= \frac{2π}{3R1}j0 (r3-R13)
4) Thus the amperes law gives ∫Bdl=μ0\frac{2π}{3R1}j0 (r3-R13) and B2πr=μ0\frac{2π}{3R1}j0 (r3-R13) so B=μ0\frac{2π}{3R1}j0 [r2-(R13/r)]
5) For r>R2, outside the cylinder, the amperian loop will include the total current which the same as Ienc but for r=R2 so Itotal= \frac{2π}{3R1}j0 (R23-R13)
6) And applying the ampere's law again into a loop radius r>R2 it gives B= (μ0j0/3r)[(R23/R1)-R12]
7) It seems that in the Oy,Oz axis the magnetic field is the same and outside the cylinder it decreases with a ratio 1/r. The magnetic field is doing loops around the cylinder and inside the area with the current in the \hat{φ} direction.
I am not sure if what i did is correct and the conclusions i made. Can you comment please?
Right.
Wrong. Why did you not integrate dI = 2 pi j r' dr' from R1 to r?
rude man said:
Right.
I thought that if the current is in the green area, then the integration is from R1 o r.
EDIT: i saw it now. I did integrate from R1 to r..i forgot to put the 'd' in the r2..so it is dr2 in the first step
Not sure I understand that.
Actually however, you did everything right in your original post except when it came to evaluating B for case 2 where you forgot to divide by 2 pi.
I'm sorry, your expressions fooled me for a while but they were mostly OK all along.
never mind that, it was a mistake i thought i did :)
thanks for your reply you really helped me
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
