Comp Sci Amplitude of Analog Filter Question
The discussion revolves around the calculations related to the amplitude of an analog filter, specifically focusing on reactance and impedance. Participants emphasize the importance of correctly identifying the signs of capacitive and inductive reactance in calculations. There is a consensus that at resonance, the reactance should equal zero, leading to a deep notch in output voltage. The need for careful handling of complex numbers in impedance calculations is highlighted, particularly the use of the imaginary unit 'j' to maintain orthogonality between real and imaginary components. Overall, the conversation underscores the necessity of methodical approaches in electrical engineering calculations.
nao113
Calculate V/E of the circuit below. I tried to calculate this one, is it correct? Thank you
Vc = 1/jwC
Question
Answer;
That does not look right to me.
You have a potential divider.
Reactance; Xv = XL + XC;
But what is the sign of XC ?
Impedance; Ztotal = R + jXv
The output V = E * jXv / Ztotal
How about this one?
2nd guessing will not educate you, nor solve the problem.
At the frequency where L and C are resonant, there will be a deep notch with V = 0.
How can XL + XC = 0 ?
thank you for the feedback, what do you mean by 2nd guessing? for `How can XL + XC = 0 ?` what should I do for that question? Did I got it wrong for my calculation?
What is the reactance XL of an inductor?
What is the reactance XC of a capacitor?
based on my class, here it is
Both XL and XC are imaginary. R is real.
So XL + jXC does not equal Xv. Both XL and XC lie on the same axis.
Xv = ωL - 1/ωC
Then you fail to divide.
Then, I remove the imaginary, how about it?
You must move more methodically and accurately.
You removed the j, but immediately ignored the negative sign, then forgot to divide.
how about this? I am sorry, I am new in this area so kinda confused
I wouldn't multiply XL by j, and then divide XC by j . That does not seem fair.
Z = R + j X;
If you work on the reactance, X only, you can ignore j for the moment.
You are having problems with fractions.
X = ωL - 1 / ωC = ( ωC·ωL - 1 ) / ωC .
I am so sorry, I didn't realize it
I revised again
Resistance, real, is plotted along the x-axis, reactance, imaginary, is on the y-axis. Impedance is a point on the map, represented by a complex number. Below the x-axis is negative, so it is a capacitive reactance, above the x-axis is inductive reactance. Resonance lies on the x-axis, where reactance is zero.
You must introduce j when you write a complex impedance, because it keeps the orthogonal real and imaginary axes apart. Z = R + jX is prevented from becoming Z = R + X by the presence of j.
So in your second line you must carefully identify the reactance components with j .
is it? do I need to change plus to minus after R in Z total? Then for |V/E|, did I put quadrat and roots correctly? should. I also put root on the top?
Now you are going to need to propagate that R + j ( ) along the second line;
That is needed to keep the impedance orthogonal.
That is needed to keep the impedance orthogonal.i
how about this? is this what you mean as propagate?
Baluncore said:
I think you need to brush up on your complex arithmetic.
https://en.wikipedia.org/wiki/Complex_number
V = E * ( 0 + j Xv ) / ( R + j Xv )
So you need to divide an imaginary by a complex.
Thank you very much, I see, I think my answer is still not correct. I ll try to learn your suggestion.
