How Is the Amplitude of a Membrane's Oscillation Determined by Sand Jumping?
In summary: To find the point of divergence, you want to look at the acceleration of the membrane compared to the acceleration due to gravity.##a_m = \frac{d^2}{dt^2} A\sin(\omega t)##And find when ##a_m < g##, that will be the point where the two diverge.
cdummie
147
A little amount of sand is spilt over horizontal membrane that oscillates with frequency f=500Hz in vertical plane. If sand grains are jumping to the height h=3mm with respect to the equilibrium position, find amplitude of oscillation of membrane.
ω=2πf
I know that there are two forces acting on the sand when it's on the membrane, first one is gravity and the second one is force between sand and membrane. I know that at some point, sand will jump off the membrane, but i don't actually know when. Is it going to happen in the moment when membrane reaches maximum elongation (amplitude) or before and why?
Sorry about the last mispost
have you transferred the frequency information into a vertical displacement function yet?
Once you do that, you should be able to see when the membrane and sand particle positions diverge.
I am sorry but i don't know how to transfer frequency into vertical displacement function. Can you help me with that?
Normally it will look like
##A\sin(\omega t)##
Where A is the amplitude you are looking for.
Likes cdummie
While it is on the membrane, they have the same velocity. At what point will the velocities start to diverge? Think about accelerations.
##A\sin(\omega t)##
Oh, that's what you meant, i didn't knew it's called vertical displacement function, i always refer to it as elongation in function of time, anyway, what's with the starting phase, is it zero or what?
Maybe when they reach equilibrium point, but i am not sure, could you explain it to me?
I don't think it really matters. You are given the maximum height of the bounce, so I would look for maximum upward velocity.
Your position function for the sand would be:
**edited** ##p_0 +v_0t-4.9t^2##
where p_0 and v_0 refer to the position and velocity when the sand leaves the membrane.
For simplicity, I recommend assuming that since omega is large, it will be almost immediately after reaching maximum velocity.
(this can be backed up semi-rigorously by looking at approximations of ##\sin x## for small x).
Thus, use maximum upward velocity as your starting point.
Find out what velocity is required to move something 3mm. Work backward from there to find your amplitude of oscillation.
##p_0 +v_0+vt-4.9t^2##
So when ##a_m-g<0## they diverge, since ##a_m=-Aω^2sinωt## it means that ##-Aω^2sinωt<g## but what i am supposed to do next, we will have maximum velocity at equilibrium point, since after reaching equilibrium point it begins slowing down, right? Now, i should, as you said, use maximum velocity as starting point, but i don't know how to use it when i don't know what velocity it is, how can i determine it? I mean i could use the fact that, in order to move something to some height, i need to have force that is equal to sum of gravitational force and inertia force. but i don't know the value of inertia force so i am not sure what can i do here.
Velocity of the membrane is the first derivative w.r.t. time and will be ##A\omega\cos (\omega t)## which has a maximum of ##A\omega## when ##A\sin(\omega t) = 0##.
Impart your particle with initial velocity of ##A\omega## starting from an initial height of 0m. Solve for A.
Time to peak: ## v_0 - 9.8t = 0 m/s##
Height at time t: ## s(t) = v_0t -4.9t^2 =.003 m ##
Likes cdummie
Still the membrane exerts an upward force (normal force, N) on the sand grains, they stay on the membrane and move together with it. Find the condition when N becomes zero: at that moment the grains and the membrane separate, as the membrane can not pull downward the sand. Determine the velocity of the sand grains at that moment.
Ok, let's see, N will be zero when gravity loses it's effect on the sand, which means, when velocity of the sand (along with the membrane) is such, that it's acceleration is equal to gravity acceleration, just with opposite direction. Is that right?
Right, except that I would not say "when the velocity ... is such that." It is simply when the acceleration upward is equal to gravity downward.
1. What is the definition of amplitude of oscillations?
The amplitude of oscillations is the maximum displacement of a vibrating system from its equilibrium position. It is measured in units of length, such as meters or centimeters, depending on the system being studied.
2. How does the amplitude affect the energy of oscillations?
The amplitude of oscillations is directly proportional to the energy of the system. This means that as the amplitude increases, so does the energy. This relationship can be seen in systems such as a swinging pendulum, where a larger amplitude results in a longer period and therefore more energy is required to maintain the oscillations.
3. Can the amplitude of oscillations change over time?
Yes, the amplitude of oscillations can change over time. This can be due to external forces acting on the oscillating system, such as damping or resonant forces. It can also be affected by the system's own characteristics, such as natural frequency or stiffness.
4. Is there a limit to the amplitude of oscillations?
In theory, there is no limit to the amplitude of oscillations. However, in practical applications, the amplitude is limited by the system's ability to withstand the forces and maintain its stability. For example, a bridge can only withstand a certain amount of oscillations before it collapses.
5. How is the amplitude related to the frequency of oscillations?
The amplitude and frequency of oscillations are inversely proportional. This means that as the frequency increases, the amplitude decreases, and vice versa. This relationship can be seen in systems such as musical instruments, where changing the frequency of vibrations changes the amplitude of the sound produced.
