Convert LNA 433MHz Signal (21dB) to DC Voltage - Ryan's Question
  • Thread starter Thread starter RLovelett
    Amplitude Dc
To convert a 433MHz LNA signal (21dB) to a lower frequency, a mixer circuit is recommended. For converting a 50MHz sine wave signal to a proportional DC voltage, a detector diode is suggested. These components will help achieve the desired signal processing. The discussion focuses on practical circuit solutions for signal frequency reduction and amplitude-to-DC conversion. Understanding these components is crucial for effective signal manipulation in RF applications.
RLovelett
My scenario:
LNA 433MHz signal (21dB) from antenna and the difference between the two signals with a 4.1dB gain. I would like to take the result of the difference amplifier an produce a DC value that is proportional to the output.
Question 1:
What type of circuit would lower the frequency to something like 50MHz?
Question 2:
What type of circuit would take the amplitude of a 50MHz sine wave signal and convert it to a DC voltage that is proportional?
Many thanks!
Ryan
Answer 1:
A mixer
Answer 2:
A detector diode.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
