An electric potential is given in volts by
The electric potential is given by the equation φ(x,y,z) = 20x - 12y² + 2yz, and the task is to find the electric field E at the point (1,1,3). The electric field is calculated using the equation E = -∇φ, where ∇φ represents the gradient of the potential. There was confusion regarding the calculation of the gradient and whether to sum the components, as the gradient results in a vector rather than a scalar. The correct approach involves determining the components of the electric field vector and then calculating its magnitude. The discussion clarifies the distinction between scalar and vector quantities in this context.
zhillyz
An electric potential is given in volts by;
\phi (x,y,z) = 20x - 12y^2 +2yz,
where x,y and z are measured in metres. Find the magnitude of the electric field E at the point(1,1,3).
E = -\nabla \phi
-\nabla \phi = -1*(\frac{\partial \phi}{\partial x} + \frac{\partial \phi}{\partial y} + \frac{\partial \phi}{\partial z})
= -1*((20)+(24y +2z)+(2y)) = -1*(20+24+6+2) = -52Vm^-1
I just wanted to know if I have used the right equation, the process is okay and if there is an occasion I should not use this equation? Thanks!
hi zhillyz! :smile:
zhillyz said:
E = -\nabla \phi
no, ∇ is a vector
(and the magnitude of (a,b,c) isn't a + b + c, is it? :wink:)​
I'm sorry perhaps you could elaborate but I think that the electric field 'E' is equal to negative grad phi, grad being the gradient of a vector as you say. Do you merely mean I should not add the sums together at the end as this would make it scalar? ie,
20i +30j+2k
zhillyz said:
… grad being the gradient of a vector as you say …
no, phi is a scalar, grad phi is the gradient of a scalar, it is a vector
what is the magnitude of a vector (a,b,c) ? :smile:
-20i + -30j + -2k = E, |E|= \sqrt {(-20^2) + (-30^2) + (-2k^2)}
Better?
yup! :biggrin:
(i'm assuming that last "k" is a misprint :wink:)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
