An integral by parts problem - please advise
insane0hflex
The function is increasing and has a inverse f^-1
Also assume f′is continuous and f'(x) > 0 over the state interval of integration [a,b]
PLEASE NOTE! a is lower limit, b is upper limit (same for alpha and beta symbol later on)
Used integration by parts to show that:
\int f(x)dx=bf(b)−af(a)−∫ba xf′(x)dx
Then if y = f(x), then the following is true (used the substitution rule)
\int _a ^b f(x) \: dx = bf(b) - af(a) - \int _{f(a)} ^{f(b)} f ^{-1} (y) \: dy
The question: Now, I need to show that if α = f(a), and β = f(b), then
∫βαf^-1(x)dx=β f^-1(β)−α f^-1(α)−∫f^-1(β)f^-1(α)f(x)dx
trying to fix the problem's display. B should be the upper limit, a should be lower limit when next to an integral sign
Im lost. I'm sure its something relatively easy to do, maybe another substitution or relevant manipulation?
Help appreciated!
It isn't true. Try f(x) = x, a = 1, b = 2.
\int f(x)dx=bf(b)−af(a)−\int_{\,b}^{\,a} xf'(x)dx
\displaystyle \int_β^αf^{-1}(x)dx=β f^{-1}(β)−α f^-1(α)−\int_{f^{-1}(β)}^{f^{-1}(α)}f(x)dx
I'm lost. I'm sure its something relatively easy to do, maybe another substitution or relevant manipulation?
Help appreciated!
You have a few (apparent) typos, which I attempted to fix.
You have worked out most of the result.
(To view the LaTeX code, right click the desired expression and choose "Show Math As: TEX Commands".)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
