Craplegend
- 4
What are 2 applications of an oscillator circuit, I need help with this!? I can only find one...
thanks for any help
thanks for any help
Fair enough. On that line of thought, where would you expect to find another need, then?Craplegend said:Thank-you for the welcome :D
For use in a transmitter, that's the one I know
Sorry? Is that an answer, or another question, or what??I also need 2 for a filter...
NascentOxygen said:Sorry? Is that an answer, or another question, or what??
An analogue oscillator is an electronic circuit that produces a repetitive, fluctuating signal. It works by converting a direct current (DC) input into an alternating current (AC) output, which can then be used for various purposes such as generating sound or measuring frequencies.
The two main applications of an analogue oscillator are signal generation and frequency measurement. In signal generation, the oscillator is used to produce a specific type of waveform, such as sine, square, or triangle waves, which can be used in audio equipment, radio transmitters, and other electronic devices. In frequency measurement, the oscillator is used to generate a known frequency that is compared to an unknown frequency, allowing for precise measurement of the unknown frequency.
Some common types of analogue oscillators include the Wien bridge oscillator, Colpitts oscillator, and Hartley oscillator. These are all based on different circuit configurations and have their own unique characteristics and applications. Other types include the phase-shift oscillator, crystal oscillator, and voltage-controlled oscillator (VCO).
A digital oscillator produces a digital output, which means the output signal can only have two possible states: high or low. An analogue oscillator, on the other hand, produces an analogue output, which can have a continuous range of values. This makes analogue oscillators more versatile and suitable for applications that require precise control over the output signal.
When choosing an analogue oscillator, some important factors to consider include the frequency range, stability, accuracy, and power consumption. The type of waveform and output voltage also play a role in selecting the right oscillator for a specific application. Additionally, cost and size may also be important considerations depending on the application.
