Analysis of a function(relatively easy)
  • Thread starter Thread starter Wingeer
    Analysis
Wingeer
Given the function:
f(x)=\left\{<br /> \begin{array}{cl}<br /> x+2x^2\sin\left(\frac{1}{x}\right), &amp; x\neq 0 \\<br /> 0, &amp; x=0<br /> \end{array}\right.
& f&#039;(0)=1
"Show that all intervals containing x=0, will also have a point where f'(x) < 0. (This shows that even if f'(0) > 0, f is not increasing on any interval containing x=0"
Well, this is part b of a problem. Part a was to find f'(0)=1, which I did by the mean-value theorem.
If I could just get a hint on how to solve this, part b, I will attempt a solution.
Write out f'(x) and think about what values it takes for x=1/(n*pi) where n is an integer.
How did you "use the mean value theorem" to find f'(0)= 0?
Well, now you are making me unsure. But this is what I did:
f&#039;(0)= \frac {f(1)-f(-1)}{1-(-1)} = \frac {(1+2 sin(1))-(-1 +2 sin(-1))}{2} = \frac {2+2 sin(1) - sin(-1)}{2} = \frac {2}{2} = 1
Aside from being numerically wrong, that's not the definition of the derivative f'(0). Don't you have to take a limit to find f'(0)?
Well. By the definition of the derivative, we have got f&#039;(x) = {\lim}\limits_{h \to 0} \frac {x + 2(x+h)^2 \cdot sin( \frac{1}{x+h}) -(x + 2x^2 sin (\frac {1}{x}))}{h}
Edit: flaw in the expression. Thanks to Dick for pointing it out.
That getting there. But you want f' when x=0. That makes (f(x+h)-f(x))/h just (f(h)-f(0))/h. Since f(0)=0, that's just f(h)/h. BTW don't forget the x term in the definition of f(x).
Did I forget something?
Yes, I see it now. The reason I didn't do this at first, was that I filled in, then substituted x with 0, and therefore got some undefined trigonometric identities.
Edit: Which I now see is defined by the definition of the function. My head is not top notch today.
My point was that knowing that (f(1)- f(-1))/(1-(-1))= 1 only tells you that there is SOME x between -1 and 1 such that f'(p)= 1, not that that point is x=0!
The reason I asked instead of simply saying that the mean value theorem wouldn't work is that if you could find a sequence of points \{x_n\} such that (f(x_n)- f(-x_n))/(x_n- (-x_n))= 1 then you could "squeez" that point to x= 0, but I couldn't see how to do that.
In any case, as Dick told you, the basic formula f&#039;(0)= lim (f(h)- f(0))/h works.
Yes, I get it now. The second task is still a bit diffuse to me though.
You are probably overlooking post 2.
