Analysis of Billiards Ball Motion Following a Horizontal Queue Impact
The discussion focuses on analyzing the motion of a billiards ball after being struck by a cue. Participants are tasked with determining the speed of the ball's center of mass and its angular momentum immediately post-collision, using parameters such as mass, height, and force. The conversation highlights the importance of impulse in linear momentum and torque in angular momentum calculations. A key point raised is the need to express torque in relation to force, height, and radius. The second question clarifies the requirement for the cue's impact height to ensure the ball rolls without slipping after the collision.
besnik93
1. Encountered with cue to a massive billiards ball, which is initially at rest, see figure uploaded. The ball has radius R and mass M. The queue hits with force F horizontally into the bale height h above the table, and the shock lasts a very short time Δt.
It is reported that the moment of inertia of the ball with respect to its center of mass is
I = 2/5 * M * R^2
The movement after the shock is a combination of a translational movement and a rotation about an axis through the center of gravity perpendicular to the plane of the paper.
a) Determine the speed of the billiard ball's center of mass and billiard ball's angular momentum with respect to the center of mass immediately after the collision. The answers must be expressed by the known sizes M, h, R, F and Δt.
b) At what height should the queue hit the ball to the ball immediately after the collision rolls without slipping?
a) i think of focusing on the the center of mass, but how, i don't know..
b) i know that i need to focus on the expression of the mass center point of the speed and bale angular velocity. But i can't move on.
so i hope someone can help me, please..
Note that the change in linear momentum = F x Δt, called an impulse. The change in angular momentum would equal T x Δt, where T equals torque. Can you express torque as an equation using F, h, and R?
I don't know how to express that to make sense
You guessed right with using the center of mass as the reference point.
The speed of the ball after the perfectly elastic collision is a very simple conservation of momentum:
F Δt = M v
The speed of the ball's angular momentum would then be conservation of angular momentum where you take the moment or torque about the ball's center of mass:
F Δt (h-R) = I ω
I think question b) is not stated quite correctly. I think it should read as follows:
b) At what height should the queue hit the ball so that the ball immediately after the collision rolls without slipping?
b) yes that's it
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
