Analysis Questions-Thanks for helping me
  • Thread starter Thread starter BustedBreaks
    Analysis
BustedBreaks
Analysis Questions--Thanks for helping me!
I have a final in an introductory analysis class that covers mostly sequences and series on Friday and I'm a bit behind in the course work. I have a bunch of questions so instead of making a different thread for each one I figured I would just use this one. All the posts with questions will be in bold to distinguish from responses. Thanks in advance for all your help and here's the first question:
Let S be the sequence <x_{n}>_{n} where:A.x_{n}=1+\frac{(-1)^{n}}{(n+1)}}, for n=0,3,6,9,...
B.x_{n}=-1+\frac{1}{n}}, for n=1,4,7,10,...
C.x_{n}=\frac{1}{2}+\frac{3}{n}, for n=2,5,8,11,...
Determine
1. The limsup of S.
2. The liminf of S.
3. Whether S has a limit. The limit as n goes to infinity for A is 1
The limit as n goes to infinity for B is -1
The limit as n goes to infinity for C is 1/2
So there is no limit, to answer 3, because the limits for each subsequence do not equal each other, correct?
I'm not sure what to do about liminf and limsup...
I want to say that the liminf is -1 and the lim sup is 1, but I'm not sure if my reasoning is correct. I just took the least and greatest of the limits as it approaches infinity. Another answer could be that the lim inf is 0 because that is the smallest first number of the sequence, but I don't think that's right because by that logic you can find smaller numbers by using n greater than 0 etc which is why I think taking the infinite limit is the right answer.
Well, what is the definition of "limsup" and "liminf"? The limsup of a sequence is the supremum of the set of all "subsequential limits" and liminf is the infimum of that set. And, of course, for a finite set of numbers, "sup" and "inf" are just the largest and smallest numbers in the set. Can you see that because every number in the sequence is in one of those three subsequences, that converge to -1, 1/2, and 1, those are the only "subsequential limits"?
Yes, that's what I think I was thinking. So then the Limsup would be 1 and the liminf would be -1 because these are the greatest and least limits of the subsequences which compose all of S? What does that make 1/2? Is it relevant to limsup/ liminf?
Yes.
Just another subsequential limit.
No.
The next question is: Determine real numbers a_{n}, n=0,1,2,... such that
sin x + cos x =\sum^{\infty}_{n=0}a_{n}x^{n}
In addition determine the radius of convergence of the power series.
Could I generalize the sum of the series for sin x and cos x?
Here's what I'm trying:
<br /> <br /> sin x =\sum^{\infty}_{n=0}\frac{(-1)^{n}x^{2n+1}}{(2n+1)!}=x-\frac{x^{3}}{3!}+\frac{x^{5}}{5!}-\frac{x^{7}}{7!}+...<br /> <br />
<br /> cos x =\sum^{\infty}_{n=0}\frac{(-1)^{n}x^{2n}}{(2n)!}=1-\frac{x^{2}}{2!}+\frac{x^{4}}{4!}-\frac{x^{6}}{6!}+...
adding them together:
1+x-\frac{x^{2}}{2!}-\frac{x^{3}}{3!}+\frac{x^{4}}{4!}+\frac{x^{5}}{5!}-\frac{x^{6}}{6!}-\frac{x^{7}}{7!}<br /> <br />
<br /> (1+x)-(\frac{x^{2}}{2!}+\frac{x^{3}}{3!})+(\frac{x^{4}}{4!}+\frac{x^{5}}{5!})-(\frac{x^{6}}{6!}+\frac{x^{7}}{7!})<br /> <br />
still working... am I on the right track? THANKS!
Sure, that's the series alright. You don't really need to regroup the terms. To determine the radius of convergence, I'd suggest a ratio test.
It seems to work if I just use
\sum^{\infty}_{n=0}\frac{(-1)^{n}x^{2n}}{(2n)!}+\frac{(-1)^{n}x^{2n+1}}{(2n+1)!}
as my power series, but I don' t think that is in the form the question is asking for - Determine real numbers a_n, n=0,1,2,... such that: sinx + cosx = \sum^{\infty}_{n=0}a_{n}x^{n}
Well, a0=1, a1=1, a2=(-1/2!), a3=(-1/3!), a4=(1/4!), etc etc. That's what I read from your series. What's wrong with that?
Sorry to interrupt -- I don't mean to hijack to the thread -- but in post #5 the OP regroups the terms in the sum <br /> \sum^{\infty}_{n=0}\frac{(-1)^{n}x^{2n}}{(2n)!}+\frac{(-1)^{n}x^{2n+1}}{(2n+1)!}<br />
so that the x^2 term precedes the x^3 term, and the x^3 term precedes the x^4 term and so on. Now, I know that if a series is conditionally convergent, then we can make the series sum to any number A, or even make it diverge, just by rearranging it in a specific order. Can the rearranging that the OP did possibly effect the convergence of the series to the sum sin(x) + cos(x)?
I don't think so, the theorem you are referring to is generally applied to numerical series. The theorems that are used to prove the convergence of sin(x) and cos(x) in elementary calculus involve the concept of uniform convergence.
I haven`t learned about uniform convergence yet nor about series converging to functions (though I have learned about the Taylor series of a function, but not in much depth as of yet), so I will ask this question anyway -- if I need to learn more before this question can be answered properly, please let me know:
Say x = 1, then <br /> <br /> \sum^{\infty}_{n=0}\frac{(-1)^{n}x^{2n}}{(2n)!}+\frac{(-1)^{n}x^{2n+1}}{(2n+1)!}<br /> <br /> = <br /> <br /> \sum^{\infty}_{n=0}\frac{(-1)^{n}}{(2n)!}+\frac{(-1)^{n}}{(2n+1)!}<br /> <br />.
This should converge to sin1 + cos1 and this is a numerical calculation. Is it possible that rearranging the series now would affect the sum of it?
Sorry, I should have been less vague. No, it will not, because there is a theorem that deals with the convergence of power series which states that a few conditions, series such as sin(x) will converge uniformly and absolutely at any point.
Thanks snipez. Sorry for derailing the thread!
Here's another question:
Determine the power series expansion about x=1/2 of the function f(x) where:
f(x)=\frac{1}{(1-x)}
Okay, I know that the power series expansion of
is
1+x+x^{2}+...
I saw my teacher do something where he wanted to get the power series expansion about
a so he made x=a+(x-a) and plugged that in for x and then did some other things I don't remember because I didn't write it down...
A series expansion around x=1/2 is an expansion in powers of (x-1/2). So maybe you should rewrite 1/(1-x) so it contains an (x-1/2). Also wouldn't be a bad idea to write something down sometimes.
The funny thing about that is used to try to copy everything all of my teachers ever wrote down and I found that I would never use my notes to learn material nor would I remember what it was I was writing, so for this class I decided to try hard not to take too many notes and pay more attention...
This is what I get:
f(x)=\frac{1}{1-(\frac{1}{2}+(x-\frac{1}{2}))}=1+[\frac{1}{1-(\frac{1}{2}+(x-\frac{1}{2}))}]+[\frac{1}{1-(\frac{1}{2}+(x-\frac{1}{2}))}]^2 ...
but still not sure what to do now...
Write it as 1/(1/2-(x-1/2)). Now what? You want to get it in the form A/(1-B*(x-1/2)). Then the expansion goes A*(1+(B*(x-1/2))+(B*(x-1/2))^2+...).
So I have
\frac{1}{(\frac{1}{2})-(x-\frac{1}{2})}
then I turn it into the form \frac{a_n}{1-(x)} by multiplying by 2/2 and get
\frac{2}{(1-(2x-1)}
then sub u for (2x-1)
\frac{2}{1-u}=\sum^{\infty}_{n=0}2u^{n}, u=2x-1
=2(2x-1)^{0}+2(2x-1)^{1}+2(2x-1)^{2}...
=2+2\cdot2(x-\frac{1}{2})+2\cdot2\cdot2(x-\frac{1}{2})^{2}...
=\sum^{\infty}_{n=0}2^{n+1}(x-\frac{1}{2})^{n}
That's it.
Suppose that &lt;x_{n}&gt;_{n} is a sequence of integers such that for all n: 0\leq t_{n}\leq9. Show that the series:
\sum^{\infty}_{n=0}t_{n}10^{-1}
converges and determine lower and upper bounds.
Here is what my TA wrote for me:
0\leq a_{n}\leq b_{n}
\sum b_{n} converges \Rightarrow \sum a_{n} exists.
a_{n}=t_{n}10^{-1}
a_{n}\leq \frac{9}{10^{n}}=b_{n} (this is off to the side: \sum_{n}a_{a}x^{n})
and \sum_{n}b_{n}=9\frac{1}{1-\frac{1}{10}}
So \sum a_{n} converges.
I'm having a little trouble understanding why he chose \frac{9}{10^{n}} for b_{n} and where he went from there.
Thanks
Um, because b_n is an upper bound since t_n is between 0 and 9 inclusive (in particular, t_n is less than or equal to 9)? This is just the basic comparison test. Then \sum^{\infty}_{n=0} \frac{1}{10^{n}} is just a geometric series (infinite) which evaluates to \frac{1}{1 - \frac{1}{10}}.
Thanks, I understand that now.
Discuss the sequence &lt;x_{n}&gt;_{n} where:
x_{n}=(1+\frac{1}{2}+...+\frac{1}{n+1})\cdot(n+1)^{-1}}
Discuss convergence, what the bounds are etc...
The sequence goes to 0 as n goes to infinity.
What are the bounds?
I think you are supposed to at least try to solve it or express some sort of opinion on the question. What do YOU think?
Just wanted to say thanks to everyone who helped, I don't know what I got on the test yet, but I did get a B in the class and the grade was based on the final! Thank you, Thank you.
