Analytical Geometry HW: 1.2.1, mPR & mRN Solutions
The discussion focuses on the homework problem 1.2.1, where the calculations for the slopes mPR and mRN are presented. The correct slope for mPR is confirmed as 1/2, but the tangent calculation is clarified as arctan(1/2) equating to 26.57 degrees, not tan(1/2). The value for mRN is noted as -1/5, with a reference angle of 11.32 degrees. There is confusion regarding the notation \hat{R}, with suggestions that it may refer to the magnitude of the vector from O to R rather than a unit vector. Overall, the calculations need clarification on the intended meaning of \hat{R} and the correct interpretation of the tangent function.
DERRAN
http://img23.imageshack.us/img23/8680/68366634.gif
1.2.1 only!
mPR=1/2
tan(1/2)=26.57
mRN= -1/5
ref angle=11.32
R=11.32+26.57
=37.88
is it correct?
1.2.1 only!
mPR=1/2
tan(1/2)=26.57
mRN= -1/5
ref angle=11.32
R=11.32+26.57
=37.88
is it correct?
I don't think so. The problem asks for \hat{R}. The caret (or "hat") is usually interpreted to mean a unit vector, but that's probably not what is meant here, since the magnitude of any unit vector is 1. I think that what is asked for is the magnitude of the vector from O to R. You seem to have calculated the measure of angle PRQ. Since it's not clear to me what \hat{R} is intended to represent, it's unclear to me what this problem is asking you to do.
Your calculation of the slope of PR is correct, but this isn't:
tan(1/2)=26.57
You can say that arctan(1/2) = 26.57 degrees, or that tan-1(1/2) = 26.57 degrees, where both are approximations.
That
