Analytical solution for thermal stresses in a rectangular plate
The discussion focuses on finding an analytical solution for thermal stresses in a rectangular plate with traction-free surfaces and a parabolic temperature change along the y-axis. Initial confusion arose regarding boundary conditions, but it was clarified that all edges are free to move. Participants suggest potential solutions involving functions like cosine and polynomial combinations. They note that while direct stress normal to a free edge is zero, other stress components can still exist. The conversation emphasizes the complexity of shear strains and their impact on stress distribution.
Sargam
Hello everybody,
I am solving a 2D problem of thermal stresses in a rectangular plate in which temperature is changing only y direction. Plate has fixed displacement conditions. Could anyone help me to find out analytical solution of thermal stresses for my problem? Does anyone suggest me where I can find analytical solution?
Thanks in advance.
Sargam
What are "fixed displacement conditions"?
Solutions could be something like a parabola or a cosine in the transverse direction, multiplied by a tanh in the expansion direction. Try a few ones.
Hi,
Thanks for the reply. I have mistakenly mention fixed displacement boundary condition but actually all surfaces of rectangle are traction free (free surfaces). Temperature change is parabolic on y-axis.
Could you please let me know where I can get analytical solution for this problem?
If temperature is uniform along the X axis and all edges are free to move, stress is zero everywhere, whatever the profile is along the Y axis.
In the more general case, try a product of cos(x) and cos(y) with different harmonic periods - but a particular polynomial solution can look good.
I think I can see how you reached that (wrong) conclusion, but what about non-zero shear strains in the plate, and the stresses they create?
The direct stress component normal to a free edge must be zero, but the other stress components along a free edge need not be zero. Axial tension in a rod is a simple (non-thermal) example.
Right!
It must be something like tanh(x) times a polynomial of y.
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
