Angle Between F1 and F2 Forces on Disk Sliding on Ice
The discussion focuses on calculating the angle between two forces, F1 and F2, acting on a 1.8 kg disk sliding on frictionless ice. F1 has a magnitude of 3.0 N in the negative x-direction, while F2 has a magnitude of 9.0 N but an unknown direction. The velocity graph indicates that the disk's velocity changes from -4 m/s to +5 m/s over time, allowing for the calculation of acceleration as the slope of the graph. Using Newton's Second Law, the forces can be summed to find F2's components, with F2x determined through the cosine of the angle. The final goal is to solve for the angle 'd' after finding acceleration from the graph's slope.
KMjuniormint5
The question is:
Two horizontal forces F1 and F2 act on a 1.8 kg disk that slides over frictionless ice, on which an xy coordinate system is laid out. Force F1 is in the negative direction of the x-axis and has a magnitude of 3.0 N. Force F2 has a magnitude of 9.0 N. The figure below gives the x component vx of the velocity of the disk as a function of time t during the sliding. What is the angle between the constant directions of forces F1 and F2?
The graph is a Vs(m/s) vs t(s). It starts down at -4 m/s when time = 0 and it is a staight line up to +5m/s at time = 3 and the function crossed the x-axis around 1.3333ish (doesnt give an exact point).
how do I go about interupting this graph to help give me F2net . . .I think i know how to get the angle and I know that . . .
F1x = 3.0 N and F1y = 0 N so. . how to get F2x and F2y from the graph. .
Hint to Sliding Forces Problem
Let's list all given data.
- 1.8 kg disk
- F1 = -3.0 N (because it go in negative direction)
- F2 = 9.0 N (but we don't know which direction it go)
- a = ? (it will be slope of your graph because your graph show velocity and if you derivative the velocity then you will get acceleration)
Use Newton's Second Law, Force = Mass x Acceleration.
The Force will be sum of F1 and F2. The Mass will be mass of disk. The Acceleration will be the slope of your velocity graph.
You will need to find F2x. (Note: the graph will not help you to find it.) Use cosine. The answer for F2x will be F2x = 9.0cos(d)
Set up an equation.
F1 + F2 = M x A
-3.0N + 9.0cos(d)N = 1.8kg x A
Go ahead find acceleration, then solve for angle 'd'. Let me know if you need any more hint and help.
