Angle between two vectors (Only by having their lengths)
  • Thread starter Thread starter Driverfury
    Angle Vectors
6 replies · 2K views
Driverfury
Ok guys, I'm studying Physics and I started, of course, by learning about vectors.
So I have this problem:
There are two vectors: A (its length is 3 m) and B (its length is 4 m). I have not other informations about them.
I want to know how I can dispose them to get a vector S (which is A + B) such as:
a) its length is 7 m.
b) its length is 1 m.
c) its length is 5 m.
Now, I know that the points a and b are obvious but I want a rigorous solution which is valid for point c and for every other length of the vector S.
Note[/B]: From now on when I write a I mean the length of the vector A. When I write b I mean the length of the vector B. Let's call o the agle between them.
Maybe this equation will be useful.
cos(o) = (A . B) / (a b)
I tried but I cannot evaluate the scalar product A . B because it is equals to (a b cos(o)). And if I replace it in the equation I have:
cos(o) = (a b cos(o)) / (a b) = cos(o)
I need your help.
Can you think of a way of writing the length of the composite vector using only the inner product and the lengths of A and B?
You have ##|A||B|\cos(\theta) =A \cdot B##. I am not sure that is exactly what you want to do, since C= A+B.
In theory, let's say you make A point along the x axis. A + B would be ##( |A| +B_x)\hat x + B_y \hat y## which is adding the part of B in the x direction to A and the remaining component of B is in the y direction.
##B_x## can also be thought of as ## B\cdot \hat x ## and similarly ##B_y = B\cdot \hat y = B - B_x##.
In more general terms, you don't even need to align A with the x axis, you could just make ##\hat a## a unit vector in the A direction.
If that still doesn't help, check your work with triangles and geometry...in that way (c) should at least be very straightforward.
Thanks for your reply. I have not specified it but I want to know the angle between the vectors A and B. For this reason I mentioned the equation: ##|A||B|\cos(\theta) =A \cdot B##.
Even if i read your reply I am still not able to evaluate the angle between them (I want a rigorous solution which is valid for every length of S).
And for evaluating I mean that I want to know how many degrees (or radians) is the angle between the two vectors. With no unknown, I want to be able to precisely evalute the angle. In (a) the angle measures 0°, in (b) the angle measures 180°, in (c) it is 90° because 5 = sqrt(a^2 + b^2).
Remember that by definition, ##s^2 = \vec S.\vec S = (\vec A +\vec B).(\vec A + \vec B) ##. You are almost there !
As you note, parts a) and b) are obvious, and part c) relates to a well-known right triangle.
If the only information you have are the magnitudes of vectors A and B and the magnitude of S, you don't have enough to go on for all possible values of |S|. For example, if |S| = 0 or if |S| > 7, there is no solution.
If S is such that it could be the third side of a triangle, you can use the Law of Cosines to find one of the angles of the triangle formed by A, B, and A + B. With that information, you could find the vector A + B.
I need your help.
Ok. Thanks for your replies, I solved.
