Angle Between Vectors given Ratio of Resultants, why is this wrong?
The problem involves finding the angle between two vectors A and B, which have the same magnitude. The relationship between the magnitudes of the resultant vectors A + B and A - B is given as a ratio, specifically that the magnitude of A + B is 75 times greater than that of A - B.
  • Exploratory, Assumption checking
  • The original poster attempts to manipulate the equation derived from the relationship between the vectors but encounters an issue with their solution. Some participants suggest verifying the logic and checking if the solution should be in radians instead of degrees. Others propose reorganizing the calculations for clarity.
The discussion is ongoing, with participants providing guidance on potential issues in the original poster's approach. There is a suggestion to check the answer key and consider the format of the answer, indicating that multiple interpretations of the problem may be explored.
There is mention of possible oversight in the calculations and the need for clarity in the presentation of the problem. The original poster expresses uncertainty about missing information, and there is a focus on the accuracy of the answer format.
Ordain
Vectors A and B have the same magnitude. Given that the magnitude of A + B is 75 times greater than the magnitude of A - B, find the angle between them?
We know that A=B, so:
2AB+2ABCos[itex]\theta[/itex]=75(2AB-2ABCos[itex]\theta[/itex])
Given that A=B
2A2+2A2Cos[itex]\theta[/itex]=75(2A2-2A2Cos[itex]\theta[/itex])
3. Attempt at a solution
Couldn't get latex to work for the fraction so:
2A2+2A2Cos[itex]\theta[/itex] divided by (2A2-2A2Cos[itex]\theta[/itex])=75
Factor out 2A2:
[itex]\frac{1+Cos}{1-cos}=75<br /> 1+Cos[itex]\theta[/itex]=75-75[itex]\theta[/itex]<br /> -74=-76Cos[itex]\theta[/itex]<br /> Cos[itex]\theta[/itex]=74/76<br /> [itex]\theta[/itex]=Cos<sup>-1</sup>(74/76)<br /> [itex]\theta[/itex]=13.2 deg<br /> <br /> Apparently this is wrong, how so?[/itex]
Hey,
Actually, the way I see it, verifying your logic and procedure, it seems fine!
Are you sure they're not asking for the solution in radians?
It might also help, to get abit of order in your calculations, to mark it as this:
Assuming the angle between the two is theta(like you said), but the ratio, for the sake of generality, we'll call alpha, that gives us:
[itex] \large<br /> |A+B|=\alpha |A-B|, |A|=|B| \Longrightarrow A^2+2A^2\cos{\theta}+A^2 = \alpha(A^2-2A^2\cos{\theta}+A^2)[/itex]
Dividing by 2*A^2:
[itex] \large<br /> 1+\cos{\theta} = \alpha(1-\cos{\theta}) \Longrightarrow \cos{\theta} = \frac{\alpha-1}{\alpha+1}[/itex]
Check to see that you have the proper answer key.
Are there any other considerations you may have overlooked?
Daniel
Thanks for that, noted for next time. This is the question in exact form, I can't find anything I'm missing.
Try entering it in radians, namely: 0.229 ~ 0.23.
What's the typical accuracy, digit significance asked? are two decimal places usually sufficient?
If so, try either 0.229, 0.23.
Daniel
