Angle does it rotate & angular acceleration?
4 replies · 5K views
DrMcDreamy
This is a two part problem, but I don't know what equation to use for part II.
a) A record has an angular speed of 15.4 rev/min. What is its angular speed? Answer in units of rad/s. 1.61 rad/s
b) Through what angle does it rotate in 1.1 s? Answer in units of rad.
What equation am I supposed to use?
A wheel rotating with a constant angular acceleration turns through 11 revolutions during a 6 s time interval. Its angular velocity at the end of this interval is 17 rad/s. What is the angular acceleration of the wheel? Note that the initial angular velocity is not zero. Answer in units of rad/s2.
Just like linear kinematics but for rotations.
Linear: position = x, speed = v
Angular: position = [tex]\theta[/tex], speed = [tex]\omega[/tex]
So for linear, you know x=x0+vt. Write out the similar equation for rotation and it will give you your angle in radians.
Same concept as before: substitute angular variables for linear ones in linear kinematics equations.
Known: [tex]\Delta\theta, t, \omega_f[/tex]
Want: [tex]\alpha[/tex]
Need: [tex]\omega_0[/tex] to get [tex]\alpha[/tex]
Work it out in two steps, first one gets you [tex]\omega_0[/tex] in terms of [tex]\alpha[/tex], plug that into another equation that relates [tex]\Delta\theta[/tex] to the everything you know so far and then solve for [tex]\alpha[/tex].
you are going to have use the appropriate angular motion equation
What is the angular motion equation that relates angular displacement with angular acceleration and time?
So it would be: [tex]\omega[/tex] = [tex]\omega[/tex] o + [tex]\alpha[/tex] t
than:
[tex]\alpha[/tex] = [tex]\Delta[/tex] [tex]\omega[/tex] / [tex]\Delta[/tex] t
There are several motion equations to choose from, and which one you use depends upon the problem. In part 1, you have a constant angular speed, and the time is given. You don't have any acceleration, it's a record spinning at a uniform angular speed. In part 2, follow 232thorium's hint.
