Angular momentum and acceleration
The discussion revolves around calculating the linear acceleration of two blocks connected by a rope over a pulley, along with the tension in the rope. Participants explore applying Newton's second law to each block and the pulley, emphasizing the importance of considering forces acting on each mass. There is confusion regarding the role of the pulley’s mass and how it affects tension. The conversation highlights the need for systematic problem-solving, including deriving equations for both blocks and the pulley to find the correct acceleration. Ultimately, the correct approach involves understanding the forces and torques acting on the system.
Felafel
m1 and m2 are two blocks tied with a rope with a pulley inbetween, like those in this picture
http://labella.altervista.org/images/mechanicsoftwopoint_2.png
there are no frictions.
find: the linear acceleration of the blocks and the tension of the rope on both m1 and m2.
I'd say it is:
## m_2 \cdot g = I \alpha + m_1 \cdot a + m_2 \cdot a## with ##a= \alpha \cdot R_0## being ##R_0## the radius of the pulley
## m_2 \cdot g= m_1 \cdot a + I \frac{a}{R_0}+m_2 \cdot a## so
##a=\frac{m_2 \cdot g}{mb + \frac{I}{R_0}}##
and then the tension of the rope on m1 is simply
T=a*m1
while the tension on m2 is
T=m2*g+m2*a
Is it correct? If not, why?
Thank you for checking :)
Does the pulley have mass?
it isn't written, but I don't think so.
Then you can forget about I for the pulley.
Apply Newton's 2nd law to each mass.
okay, thank you. :)
But if the pulley had mass, would it be right?
Felafel said:
okay, thank you. :)
No, it's not correct.
If you want to know why it's wrong, show how you got that result.
i thought ##m_2 \cdot g## is the force which moves the system, so it equals
##m_1 \cdot a## with an unknown acceleration, ##+m_2 \cdot a## because the block goes down with the same acceleration, and it also makes the pulley spin with ##I \cdot \alpha##
then I've read the formula ## a= \alpha \cdot R_0## on a book, and thought of applying it
Rather than try to do it all at once, and risk making an error, why not divide and conquer. Apply Newton's 2nd law to the two blocks and to the pulley.
like:
##F_g= m_2 \cdot g##
##F_1= m_1 \cdot a##
##F_p= I \cdot \alpha##
##F_2= F_g-F_1-F_p##
i keep getting the same result
This one I understand. Where ##F_1## is the tension in string 1.
These I don't understand.
What forces act on ##m_2##?
What forces act on the pulley? What torque do they exert?
on m2 we have the gravitational force:
##F_p=m_2 \cdot g -T= m_2 \cdot a## where T is the tension of the string
##T= m_1 \cdot a##
by subtracting the two:
##m_2 \cdot g - m_1 \cdot a = m_2 \cdot a##
and ##I \cdot \alpha= m_2 \cdot g - T ##
##I \cdot \alpha= m_2 \cdot g - m_1 \cdot a##
but i really don't know what I am doing :(
##T= m_1 \cdot a##
If the pulley had mass, the tension at its two ends shouldn't be same !
In fact,
(T1-T2)*r= Ia/r
T1 is that downward tension, and T2 leftwards.
You need to get two more equations by applying Newtons second law on each mass for translational motion.
Approach 2 : Use conservation of mechanical energy on the two blocks system.
Thank you :)!
but I don't understand how you found the left part of this equation: (T1-T2)*r= Ia/r
i mean, why is the difference between the two tensions multiplied by r?
Torque is a vector. Determine the directions of torques produced by tensions in the rope.
When applied to rotation, Newton's 2nd law becomes:
Ʃ Torque = Iα
Again, start by answering the questions I had asked earlier. What forces act on the pulley? What torques do they exert? Then you can apply Newton's 2nd law to the rotation of the pulley.
i'd say ##T_2=m_2 \cdot g## and ##T_1=M_1 \cdot a## are the only forces acting on the pulley
and so ##\Sigma \tau = (T_1- T_2)x \vec{r}## where r is the motion (which equals the radius?). which gives
##(m_2 \cdot g - m_2 \cdot a) x r = I \cdot \frac{a}{r}=##
##a=\frac{m_2 \cdot g}{\frac{I}{r^2} + m_1}## right?
Yes, the two tensions are the only relevant forces acting on the pulley. But your first equation, for block 2, is incorrect. (If ##T_2=m_2 \cdot g## then the net force on block 2 would be zero.)
Do it systematically. For the pulley:
##\Sigma \tau = (T_1 - T_2) \cdot R = I \cdot \frac{a}{R}##
That's one equation. Now write equations for each of the blocks. (The equation you wrote for block 1 is correct; fix the one for block 2.)
is block 2:
##F= -m_2 \cdot g + m_2 \cdot a##?
Felafel said:
is block 2:
Please use the same notation you used earlier. What's F supposed to be?
What forces act on block 2? What are their directions?
oops, sorry
then, on block two there should be the gravity force:
##-m_2 \cdot g## and the tension of the string: ##T_1## which have opposite directions. then the block moves downwards with an acceleration = "a"
so:
##T_2-m_2 \cdot g =- m_2 \cdot a##
Felafel said:
oops, sorry
so:
Good. Now you have all three equations. Solve for the acceleration.
