Sheneron
- 360
[SOLVED] Angular Momentum
A 4.60 kg counterweight is attached to a light cord, which is wound around a spool (refer to Fig. 10.20). The spool is a uniform solid cylinder of radius 8.00 cm and mass 1.30 kg.
(a) What is the net torque on the system about the point O?
Magnitude
(b) When the counterweight has a speed v, the pulley has an angular speed = v/R. Determine the total angular momentum of the system about O.
(c) Using the fact that = dL/dt and your result from (b), calculate the acceleration of the counterweight.
L = r X P
\tau = r X F
L = I\omega
I was able to solve the first part:
\tau = rF
\tau = (0.08)(4.6)(9.8) = 3.61 Nm
I am not sure how to solve part B though, here is what I tried but it was wrong:
L_{net} = rp + I\omega
L_{net} = r X mv + I*\frac{v}{r}
L_{net} = v (r X m + \frac{I}{r})
I factored out the v because it doesn't give you the velocity, and the answer space looks like this:
________ X v kg *m^2/s
Magnitude
L = r X P
\tau = r X F
L = I\omega
\tau = rF
