Angular momentum of a particle in a spherically symmetric potential
stunner5000pt
A particle in a spherically symmetric potential is in a state described by the wavepacked
\psi (x,y,z) = C (xy+yz+zx)e^{-alpha r^2}
What is the probability that a measurement of the square of the angular mometum yields zero?
What is the probability that it yields 6\hbar^2 [/itex]?<br /> If the value of l is found to be 2. what are the relative probabilities of m=-2,-1,0,1,2<br /> <br /> <b>2. The attempt at a solution</b><br /> <br /> i think the first part is simply aking to calculate &amp;lt;L^2&amp;gt;<br /> <br /> but the carteisna coords are throwing me off... Should i convert to spherical polars?? Till now whenever the angular momentum L^2 and Lz were required, they were gotten using<br /> \hat{L^2} \psi_{nlm_{l}} = l(l+1) \psi_{nlm_{l}}<br /> <br /> really from the spherical harmonics... however conversion to spherical polars doesn&#039;t yield any familiar spherical harmonic either.<br /> <br /> can it written in a way that yields familiar spherical harmonics, however??
Yes. Convert to spherical coordinates. You won't necessarily get a spherical harmonic but you can decompose it into spherical harmonics in the usual way you split a wavefunction relative to an orthonormal basis.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
