What is the Correct Equation for Angular Acceleration in this Flywheel Problem?
The discussion centers on the correct equation for angular acceleration in a flywheel problem, specifically addressing the confusion surrounding the definitions and calculations. The angular velocity is given as w=0.005theta^2 rad/s, and the participants debate the proper application of the chain rule in differentiating this expression. There is disagreement over the book's notation, with some asserting it incorrectly states alpha as w(dw)(dtheta) instead of the correct form, alpha=w(dω/dθ). The consensus is that the correct relationship involves using the chain rule to derive angular acceleration as alpha=ω(dω/dθ). Clarification is sought on the book's definitions and potential typos affecting the solution process.
k_squared
"The flywheel rotates with angular velocity of w=0.005theta^2 rad/s. Determine the angular acceleration after it has rotated 20 revolutions.
I thought the equations were all but self-evident using the problem description! (See below.)
alpha=dw/dt
The angular velocity is merely a=0.01theta. I just plugged in 20*2pi for the acceleration at that time and was... wrong. Massively wrong, in fact. The book solutions agrees with me about my equations for w and a, but they actually multiple the acceleration and the velocity together!
The book defines alpha as dw/dtheta... but then, in this solution set, states that alpha=w(dw)(dtheta), which is not something I can make *any* sense out of. They then use this value of alpha to compute the acceleration over a rotation of (40pi), complete with theta cubed.
What happened here? I can't make heads or tails of it.
Are you sure of this definition?
You need to use the chain rule of differentiation when applying ##\frac{d}{dt}## on ##[\theta (t)]^2##.
Likes Delta2
due to the chain rule of differentiation it is ##\frac{dw}{dt}=\frac{dw}{d\theta}\frac{d\theta}{dt}## and it is also ##\frac{d\theta}{dt}=w## so what your book says is correct.
your book is wrong, it is not $$\alpha = w\times dw \times d\theta$$
it is,
$$\alpha = {d \omega \over dt} = \underbrace{{d\omega \over d\theta } \times {d\theta \over dt}}_{\text{chain rule}} = ?$$
... assuming k2 meant alpha=w(dw)/(dtheta) and not
guys I believe the post has some typos, I believe he meant to write that his book says that a=wdw/dtheta , ##a=w\frac{dw}{d\theta}## in latex :).
I'll give you a screenshot if you want!
The book defined alpha (angular acceleration, I take it) merely as $$\frac{dw}{d\theta}$$. Then is also says that $$\alpha d\theta = \omega d\omega$$.
The exact answer has the line in it:
$$\alpha=\omega \frac{d\omega}{d\theta}$$ and using the given (.005theta) value and its derivative, multiplies them together and posits the value derived thereof to be the answer.
That is a typo in the book. It should by dt in the denominator.
$$\alpha=\omega \frac{d\omega}{d\theta}$$ .
That is correct, but you omitted the / when you wrote alpha=w(dw)(dtheta).
Likes Delta2
