Angular Simple Harmonic Motion
The discussion focuses on calculating the percentage change in the rotational inertia of a watch's balance spring, which is modeled as a hoop. The relevant equations for rotational motion and simple harmonic motion are provided, including the formula for rotational inertia. Participants emphasize that the goal is to determine the change in inertia rather than its absolute value. The conversation encourages a deeper exploration of the relationship between the period of oscillation and inertia. Overall, the thread aims to clarify the steps needed to solve the problem effectively.
LucasCammarata
1. The balance spring of a watch is a hoop 1.2 cm in diameter, with a mass of 0.65 g. If the watch is running 45 seconds per day too fast, by what percentage should the rotational inertia of the hoop be changed?
2. Homework Equations : I = mR^2
Ia = -k(theta)
x(t) = Xm Cos(wt + @) (just using @ for phase constant)
T = 2pi ( I/mgL)^0.5
3. Rotational inertia = (0.00065 kg) x (0.006)^2 = 2.34 x 10^-8 I actually have no idea where to go from there.
Hello LC, welcome to PF :smile: !
You don't want the value of the inertia, you only want the change ! So you could just as well call it ##I_0##, from which you can calculate a ##T_0##. You want a ##T_1## which is soandosmuch over soandso times ##T_0##. That tells you something about ##I_1## in terms of ##I_0## !
Cryptic ? Give it a try and post.
