Angular Velocity and Kinetic Energy Problem?
The discussion revolves around calculating the angular velocity and kinetic energy of a wheel with a moment of inertia of 16.0 kg m² and a torque of 10 N·m applied to it. The initial calculations for angular acceleration were correct, yielding 0.625 rad/s², but there was confusion regarding the terminology, as the user mistakenly referred to angular acceleration as angular velocity. To find the angular velocity after 10 seconds, the formula ω = ω₀ + αt should be used, leading to an angular velocity of 6.25 rad/s. The kinetic energy calculated using the formula KE = 1/2 Iω² resulted in 312 J, confirming the calculations were accurate. Overall, the user received validation for their approach, despite some initial misunderstandings.
keylostman
A wheel turns with a moment of intertia of 16.0kg m^2 and has 10m N applied to it. if it starts from rest calculate the angular velocity. Also what is the kinetic energy 10seconds later?
The wheels angular velocity i used T=IA, and solved for Angular velocity solving for a i got .625rad/sec^2 . For knetic energy .625rad/sec^2 i get to 6.25rad/sec. then i take 1/2IW^2, and i get 312 J
Is my work correct ? If i made a mistake , can you please tell me where ?
Hi,:smile:
If I'm not wrong (which I am most of the time), you need more data (radius of wheel and distance from the centre where the 10mN force is applied) to solve this problem :confused:
It looks OK to me, assuming you meant to find the angular acceleration (not the angular velocity). To find the angular velocity, you'd need to know at what time.
10 m N (better: 10 N-m) is a torque, not a force.
i meant the angular velocity, i wanted to find, how would i find it ?
Depends on when. You found the angular velocity after 10 s, which you needed to calculate the KE.
Did you present the problem exactly as it was given to you?
Yes Doc, its correct. THe problem is copied right
OK, I thought it was 10 milli Newton force.
May I suggest using \omega=\omega_o+\alpha t
and KE =\frac{I{\omega}^2}{2}
This is slightly ambiguous. Do they mean: 10 seconds later, calculate the angular velocity and the kinetic energy. (If so, then you did calculate the angular velocity.)
In order to calculate the velocity and KE, you must first calculate the angular acceleration. Which you did, even though you incorrectly called it angular velocity.
You never know! :wink: That's why I asked if the problem was presented exactly as given.
For angular velocity, i don't know the time, the time is implied toward the 2nd part of question
Yeah. The question's language is a bit confusing. But I feel like they want angular velocity at 10 seconds, though they don't mention it.
Why not give them a general answer
\omega=0.625t
They can plug in whatever t they want and get the result :wink:
Now you see the torture i go through to understand problems lol. All his questions are worded badly, must be cause he is from another Country heh
Thats correct mate.
