How Do You Calculate Changes in Particle Speed in Circular Motion?
In summary, the particle moves in a circle at constant speed and experienced an acceleration of 247 m/s^2.
agargento
39
The motion of a particle moving in a circle in the x-y plane is described by the equations: r(t)=3.15, Θ(t)=8.86t
Where Θ is the polar angle measured counter-clockwise from the + x-axis in radians, and r is the distance from the origin in m.
1. Calculate the x-coordinate of the particle at the time 2.20 s.
2. Calculate the y-component of the velocity at the time 2.20 s?
3. Calculate the magnitude of the acceleration of the particle at the time 1.60 s?
4. By how much does the speed of the particle change from t=10 s to t=51 s?
5. Calculate the x-component of the acceleration at the time 2.60s?
x(t) = Rcos(ωt)
y(t) = Rsin(ωt)
And their derivatives for velocity and acceleration.
[/B]
I got every question except for 4.
1. 2.52 m
2. 22.34 m/s
3. 247 m/s^2
4.
5. 124.13 m/s^2
For 4 I tried a couple of things. The first was to multiply 247*41 but that didn't work. The next thing I did was to use the equation for velocity (The derivatives of the equations above) to find the X and Y component of the velocity of each time (x,y when t=51 and x,y t=10), calculate their magnitude, and then subtract them from each other, didn't work either.
What am I missing?
What's the speed of the particle at t = 10? (How would you calculate it in general?)
Differentiate these two
x(t) = Rcos(ωt)
y(t) = Rsin(ωt)
Get the speed for t=10
And then calculate the magnitude of |x'(t), y'(t)|
Or are you asking to demonstrate it with numbers?
x(t) = Rcos(ωt)
y(t) = Rsin(ωt)
That will work.
So what do you get when you do the differentiation?
And once you have the velocity components, you can find the magnitude of the resultant velocity, which is the speed.
Likes Buffu
Doc Al said:
That will work.
x'(t) = -Rsin(ωt)*ω
y'(t) = Rcos(ωt)*ω
I know it should work but for some reason I can't get it to work...
Edit: did a more accurate calculation, the change in speed is 0 m/s :D
But now I'm a bit confused... I found the particle's acceleration... So how does the speed not change? Is it be because it has a constant radial speed, and the acceleration I found is the tangent acceleration? If so, I find it kind of confusing... Can anyone explain how can I know if I need to look at tangent acceleration or radial acceleration...?
agargento said:
x'(t) = -Rsin(ωt)*ω
y'(t) = Rcos(ωt)*ω
What makes you think the particle is changing its speed? Isn't it possible to move in a circle at constant speed?
It is. But I calculated it's acceleration in 3. and 5.
Can a particle move in a circle without acceleration?
agargento said:
x'(t) = -Rsin(ωt)*ω
y'(t) = Rcos(ωt)*ω
So far, so good. Now calculate the speed at time t. (You have the components of the velocity.)
Since acceleration is a change in velocity, not necessarily speed, just going in a circle implies some acceleration.
Doc Al said:
So far, so good. Now calculate the speed at time t. (You have the components of the velocity.)Since acceleration is a change in velocity, not necessarily speed, just going in a circle implies some acceleration.
Ohhh... So velocity has a direction and a quantity (Basically a vector) while speed is just a scalar, so when moving in a circle the velocity always changes, and that's the acceleration... ?
Not just a circle. Any change of direction implies acceleration.
Also, if the force/acceleration is perpendicular the the velocity then the speed does not change. That is what is special about motion in a circle at constant speed: the force/acceleration is always perpendicular to the velocity.
Now I understand, thanks!
1. What is angular velocity?
Angular velocity is a measure of how quickly an object is rotating around a fixed point. It is usually represented by the Greek letter omega (ω) and is measured in radians per second.
2. How is angular velocity calculated?
Angular velocity is calculated by dividing the change in angle (in radians) by the change in time. The formula is ω = Δθ/Δt, where ω is angular velocity, Δθ is change in angle, and Δt is change in time.
3. What is the difference between angular velocity and linear velocity?
Angular velocity is a measure of how quickly an object is rotating, while linear velocity is a measure of how quickly an object is moving in a straight line. Angular velocity is measured in radians per second, while linear velocity is measured in meters per second.
4. How does angular velocity affect an object's motion?
Angular velocity affects an object's motion by determining how quickly it is rotating around a fixed point. Objects with higher angular velocity will rotate faster, while objects with lower angular velocity will rotate slower.
5. What factors can affect angular velocity?
The factors that can affect angular velocity include the size and shape of the object, the distance from the object to the fixed point, and any external forces acting on the object (such as friction or gravity).
