Calculating Force on a Scale in an Elevator: A 57.0 kg Girl's Weight Measurement
  • Thread starter Thread starter lim
    Force
When a 57.0 kg girl stands on a scale in a descending elevator, the force exerted by the scale is influenced by the elevator's motion. At constant speed, the scale reads her weight, approximately 558.6 N. If the elevator accelerates downward at 2.0 m/s², the correct calculation shows the scale exerts a force of 672 N, factoring in the upward direction of the normal force and downward direction of weight and acceleration. For the scenario where the elevator's speed is decreasing, the acceleration is upward, meaning the scale's reading should reflect this change in direction. Understanding the distinction between speed and acceleration is crucial for accurate calculations in these scenarios.
lim
A 57.0 kg girl weighs herself by standing on a scale in an elevator. What is the force exerted by the scale when the elevator is descending at a constant speed of 10 m/s?
What is the force exerted by the scale if the elevator is accelerating downward with an acceleration of 2.0 m/s2?
If the elevator's descending speed is measured at 10 m/s at a given point, but its speed is decreasing by 2.0 m/s2, what is the force exerted by the scale?
F=ma, Fs-W=ma
I got the first part, 9.8(57) = 558.6 N.
For the second part I used Fs-W=ma, Fs - 558.6 = (57)2, Fs= 672 N. But that was wrong...?
For the 3rd part, I used F=ma, but F= 57 (-2) = -144 N, and that wasn't right either.
Help!
You are making sign mistakes. For the second part write Fs+W=ma. Fs is always in the up direction, so let's call that the + direction. The weight acts down so I should put that in with a minus sign, ditto acceleration is down, so put that in with a minus sign. Fs-558.6N=(57kg)*(-2)m/s^2. Now what do you get? What happens in part three?
I'm confused about part three. They give me an acceleration(-2.0 m/s^2) and I have the mass (57 kg), but how do I tie in the velocity(10m/s)?
The elevators downward speed is DECREASING. This means its acceleration is actually UPWARDS at 2m/sec^2. You do the same thing with the 10m/sec that you did in part one. The current speed doesn't have anything to do with the current acceleration.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
