Another Laws of Motion question
The discussion revolves around a physics problem involving two bricks and a 0.1 kg block affecting their motion when removed. The user initially calculated the acceleration and velocities of the blocks incorrectly, leading to a misunderstanding of their subsequent movement. After the block is removed, both bricks move at a constant velocity of 4 m/s, resulting in a displacement of 4 meters for each block in the first second. The user realizes that there is no acceleration after the block's removal, as the weights balance each other out. The thread concludes with the user seeking further clarification on related motion problems.
konichiwa2x
Hi this problem stumps me.
Two bricks each having a mass of 0.2 kg tied at the end of a light flexible cord and are passing over a small frinctionless pulley. A 0.1kg block is placed on one of the blocks and removed after 2 seconds. How far will each block move in the first second the 0.1kg block is removed?
My Work:
for one of the blocks: 0.3(10) - T = 0.3a
for the other block: T - 2 = 0.2a
solving, a = m/s^2
Then I found the velocities of each block after the 0.1kg block is removed. i,e v = 2(2) = 4m/s
actually, one of the blocks will have 4m/s and the other -4m/s.
for the block that has -4m/s velocity,
the displacement in the first second:
s = -4(1) - \frac{1}{2}(10)(1)
= -9m
and for the other block i got the displacement as 1m.
BOOK SOLUTION: my book says the correct answer is 4m for each block.
Please tell me where I went wrong. Thanks for your time!
After the one kg block is removed, there is not acceleration of the two blocks. One 2 kg block balances the other, and both contribute to the tension in the cord.
One calculated the speed a 4 m/s for one block and -4 m/s for the other block, i.e. one moves up and the other down. In one second, what is the distance traveled at constant velocity?
allright thanks. got it now:smile:
by the way, can you please look at this thread I posted earlier today?
https://www.physicsforums.com/showthread.php?t=132919 It is related to the same topic. I have been practicing laws of motion problems all day and I really want to get it straight. only that question is left..thanks
