Calculating Spring Constant for an 8kg Stone Resting on a Compressed Spring
  • Thread starter Thread starter suspenc3
    Spring
To calculate the spring constant for an 8kg stone resting on a compressed spring, the relationship between gravitational potential energy (Wg) and elastic potential energy (Ws) is crucial, where Wg = -Ws. The spring's compression of 10cm can be used in the formula Ws = -0.5kx^2 to derive the spring constant k. When the stone is pushed down an additional 30cm, the elastic potential energy just before release is calculated as U = 0.5kd^2, yielding a value of 6.27 x 10^-3 J. To find the change in gravitational potential energy as the stone moves to its maximum height, the formula delta(U) = mg[delta(y)] is applied, but the maximum height needs to be determined first.
suspenc3
An 8kg stone rests on a spring. the spring is compressed 10cm by the stone.
What is the spriong constant?
im not really sure how to start...Ws = -0.5kx^2
im guessing that there must be a relationship between Wg and Ws obviously
-Wg = Ws... but I am not sure how to solve for Ws
Can anyone help?
F = mg = -kx
b)the stone is pushed down an extra 30 cm. What is the elastic potential energy of the compressed spring just before the release?
U = 0.5kd^2 d=distance compressed
...U = 6.27 x 10^-3 J
ok...the next part asks for...
what is the change in the gravitational potential energy of the stone-earth system when the stone moves from the release point to its max height
so delta(U) = mg[delta(y)]
how do i get the max height?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
