Ansys Maxwell Simulation- Torque Fluctuating
The discussion revolves around issues encountered in an Ansys Maxwell simulation of a generator, specifically focusing on fluctuating torque readings that are not aligning with expected results. Participants explore the simulation setup, circuit configurations, and potential causes of the discrepancies in torque and voltage outputs.
  • Experimental/applied
  • One participant describes a problem with fluctuating electromagnetic torque readings around zero in their simulation of a 1KW axial flux switching generator, while output voltages appear acceptable.
  • Another participant suggests clarifying the simulation details, including the purpose and expected outputs, and requests visual outputs for better understanding.
  • A participant notes that the torque readings do not seem to fluctuate around zero but rather appear periodic with a non-zero average, questioning whether the operation is no-load and what the expected results should look like.
  • Concerns are raised about the load configuration, with one participant stating that the no-load and loaded torque values are the same, which is unexpected.
  • Participants discuss the implications of load resistance on output voltage and suggest reviewing the model for potential issues related to geometry, excitation, and motion setup.
  • One participant emphasizes the importance of testing the generator in no-load conditions and observing winding flux and voltages for symmetry.
  • There is a suggestion to consider a Delta-Wye connection for the circuit, as grounding is necessary for reference points in the simulation.
  • A participant mentions that the simulation is based on an analytically designed machine from a journal paper and expresses hope that the suggestions will lead to better results.
Participants express differing views on the nature of the torque fluctuations and the adequacy of the simulation setup. There is no consensus on the root cause of the issues, and multiple competing perspectives on circuit configuration and modeling approaches remain present.
Participants highlight potential limitations in the simulation setup, including the need for grounding in circuit configurations and the importance of reviewing model parameters and design data. There are unresolved questions regarding the expected behavior of the generator under different loading conditions.
Hamed Farnaghizad
Hi guys!
I do have a problem in ansys maxwell simulation of a generator. The moving torque (which represents electromagnetic torque) fluctuates around zero which is not correct. Induced Voltages are ok. How can I fix this problem?
The first step to solving the problem is to describe it.
1) What are you simulating? Just saying "a generator" is not sufficient.
2) What is the purpose of your simulation? What do you want to get from it?
3) Post an image of your outputs. Describe why you think some are correct, and some are wrong?
Then ask for help.
Hi @jrmichler
Thanks for your reply, actually I thought it may be a common problem in ansys maxwell.
I am simulating a 1KW axial flux switching generator. I need to have its output voltages and electromagnetic torque.
Output voltages are acceptable but torque (moving toque in rectangular plot) is as the picture below:
Hamed Farnaghizad said:
Well, this is not a "torque fluctuating around zero" in the first place. Its seems like being periodic and with non-zero avg value. Negative value means, well, that it's a generator.
First thing: is thit a no-load operation ? And second thing: how would expected result look like ?
(Sometimes model reduction + symmetry boundary may introduce some issues).
Dear @gerbi
I connected three phase windings in delta connection and connected to a three phase Y connection 100 ohms load. As I calculated torque should be around 47 Nm. One surprising thing is that , No load and Loaded Torques are the same!
100 Ohms is rated load ? I mean calculated from ohms law for generator rated voltage and current. I assume the load is also arranged in 3-phase manner.
Well, I changed output circuit as the picture attached below, but no good result.
Actually by changing the resistance of the load output voltage of the generator varies!
Phase voltage unbalance may suggest that your model has some major issues. I'm sorry, but you need to review your model (geometry, excitation, parameter, motion setup and so on) and double check it for differences when compared to original design data. Then test it in no-load conditions (increase resistance in your circuit to values like 10^6 ohm). Observe all winding flux/voltages (they must be symmetric) as well as flux distribution in generator components. That's quite standard approach for design review. If no-load operation is fine then you can move to loading your generator.
One thing I may say: it's rarely an Ansys Maxwell issue that causes a simulation to give so bad results.
Additionally, you may want to read this topic from beginning to the end: https://www.physicsforums.com/threads/ansys-maxwell-transient-torque-fluctuating-problem.926444/
@gerbi
Hi again
Sorry for delay in response
I checked everything and all the things look ok.
I think the problem is of the circuit, I used circuit editor of maxwell.
I wanted to have a Delta-Delta connection but It needs GROUND so I don't know what to do to have a DD connection.
Well, you can always have Delta-Wye connection (Delta motor + Wye load with ground)...
Otherwise just ground one of load legs (ground is needed as a reference point).
I just hope you do FEM simulation to prove some previously designed and analytically analyzed concept. Designing a machine in Maxwell is not the most optimal approach.
@gerbi
It is actually simulation of an analytically designed axial flux FSPMG, which is based on a journal paper. I will do your suggestions. I hope getting good results.
  • · Replies 18 ·
  • · Replies 20 ·
