How can I resolve assembly recognition issues in ANSYS Workbench 12?
Assembly recognition issues in ANSYS Workbench 12 can arise when importing parts from CATIA in IGS format, leading to some parts not being recognized. Users are advised to check the geometry importing options in Workbench to ensure correct settings. The IGS format can be unreliable, and obtaining a CAD Interface License for CATIA may help resolve these issues. Additionally, when creating parts directly in ANSYS, the software may merge contact surfaces, losing the intended assembly structure. For simpler models, using beam and shell elements in ANSYS Traditional could avoid these geometry complications altogether.
karimi67
hi
there is an assembly of parts which i want to do static analyse on. i make the parts in cataia and import them as ''igs'' into workbench.problem 1: there are near 7 parts in my assembly which when gets into ansys , ansys doesn't recognize some of them and doesn't show them but it recognize the other parts as solids1,2,3... what can i do if i want the whole assembly in ansys ?
problem 2: instead of importing the whole , after importing some of the parts i tried to make the other parts by its geometry feature but after making the part and pressing generate ansys automatically turns the whole assembly as one parts , i mean it doesn't know the contact sufaces anymore , it automatically merge the whole contact surfaces together . what can i do?> this are the assembly pls take a lokk
check your Geometry importing option in workbench, make sure that u r checked correct importing option. me too had the same problem, sometime it shows more surface in the assembly.
IGS format is always a 50/50 gamble. In order to do this correctly you need a CAD Interface License for Catia.
In looking at the model, I am assuming that it has no internal parts and therefore, could have been done as a simple beam and shell model in ANSYS Traditional and you would have no problems with geometry since you could have created it all in ANSYS.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
