Have you built an antigravity underground lifter before?
  • Thread starter Thread starter relativelyslow
The discussion revolves around building a lifter that uses high voltage electricity to achieve lift. The poster seeks advice on design aspects, including shape and voltage requirements, noting that most designs feature a basic triangle. They mention seeing variations with circular and hexagonal elements but are unsure if these are more effective. Suggestions for improvements or alternative engineering forums for this topic are also requested. Overall, the focus is on gathering insights for constructing an effective lifter.
relativelyslow
hola. I am not sure what specific place this should be so i figure general will do. i am in a physics club and our first project is a lifter. it apparently lifts above the ground using electricity (at least 25 kv). you can find videos and information online if you wish (amazing1.com/grav.htm has a video). so, i was wondering if there were any suggestions anyone would like to give into building this...shape, voltage, anything at all really. have any of you built one? thank you very much
There is a thread on lifters HERE. Try not to use the word "antigravity" - it triggers my gag reflex.
it didn't really give much on design. most pictures show the basic triangle. I've seen some utilizing circular with triangles and even a hexagon. is there a better shape or mixture of shapes?
anyone have any ideas? or is there a better section of engineering to post this?
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
