Any device to measure frequency of photon?
Measuring the frequency of photons typically involves measuring their wavelength or energy, as frequency is directly proportional to both. A common device for this purpose is a grating spectrometer, which can separate light into its component wavelengths. For higher precision, especially in the visible spectrum, a prism or diffraction grating can be used to determine the frequency by referencing known values. Alternative methods include measuring the energy via the photoelectric effect or using antennas for radio frequencies. Overall, the choice of method depends on the specific frequency range being investigated.
oem7110
Visible light, like sunlight, consists of photons. Each photon has a level of energy (radiant energy) directly proportional to its frequency. Does anyone have any suggestions on any device to measure the frequency of Photon?
Thanks in advance for any suggestions
One usually does not measure the frequency, but the wavelength. The most common device to do this is a grating spectrometer.
http://en.wikipedia.org/wiki/Spectrometer
Alternatively, you could try to measure the energy, e.g. via the photoelectric effect.
One normally measures their energy or wavelength and then calculates the frequency.
One can also use an antenna and look at the induced signal. This is what is often used to measure the RF frequency in cavities and accelerating structures. Something like a pick-up loop would do the job.
Zz.
Short version:
For frequencies up to ~100MHz (wavelength ~3m): just measure the electric field over time (frequency detection)
For frequencies up to ~1THz (wavelength ~30µm): Use resonance in antennas or circuits (wavelength detection)
For frequencies up to ~0.3PHz (wavelength ~100nm, energy ~10 eV): Use lenses or diffraction gratings (wavelength detection)
For higher frequencies: Measure the energy of the photons
The numbers are not hard limits, of course. They are just there to indicate different regions in the electromagnetic spectrum, where different detection methods are used.
and above ~2 keV up to 200 keV or so, use single crystal diffraction to determine the wavelength, as (more precise) alternative to measuring the energy. In that range nobody talks about frequency anymore.
If you wanted to know the approximate frequency of a visible light photon you could use a prism or diffraction grating to spread the light out (like in a rainbow). Then you would use this table from the below Wiki page to find the frequency band. If you needed a really precise frequency measurement you would need a "spectrometer". You can google that, if you want to.
Color Frequency Wavelength
violet 668–789 THz 380–450 nm
blue 631–668 THz 450–475 nm
cyan 606–630 THz 476–495 nm
green 526–606 THz 495–570 nm
yellow 508–526 THz 570–590 nm
orange 484–508 THz 590–620 nm
red 400–484 THz 620–750 nm
By the way, THz stands for "TeraHertz" and nm stands for "nanometers"
http://en.wikipedia.org/wiki/Visible_spectrum
How big is *your* spectrometer? :p
Yeah, lots of spectrometers: Fabry Perot, pushbroom, and others that are (in my mind) mostly extensions of these two.
