Any good references of Petrov Classification?
yicong2011
Is there any good references of Petrov Classification?
Thank you.
If I were to go to the nearest college library, I'd search for the 2 volumes of Penrose and Rindler's book on spinors and twistors. If I didn't find the desired treatment, then I would look in all the books Moshe Carmeli wrote.
A readable account appears in "Introduction to General Relativity" from Ryder. Personally, I learned it from Relativity: An Introduction to Special and General Relativity by Stephani.
I tried several sources to learn about this, and I still don't understand it thoroughly at all. The source that worked best for me was "Survey of gravitational radiation theory," F.A.E. Pirani, in Recent Developments in General Relativity, Pergamon, 1962, p. 89. You can presumably find it if you have access to a large university library. It's very concrete and down to earth, and it relates the ideas to their counterparts in E&M.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
