Apparent disagreement between Coulomb's Law and Gauss' Law
The discussion addresses a misunderstanding between Coulomb's Law and Gauss's Law regarding the electric field at point P, located between two point charges, +Q and -Q. Using Coulomb's Law, the electric field at point P is calculated to be E=(1/2πε0)Q/r², while Gauss's Law yields E=(1/4πε0)Q/r², leading to conflicting results. The error arises from the assumption that the electric field is symmetric across the Gaussian surface, which is incorrect in this case. The total electric field is not constant across the surface, necessitating a more complex integral calculation. Clarification emphasizes that the electric field is not spherically symmetric in this scenario.
shj
This is probably my misunderstanding, so please clarify.
In a region of empty space, there are two point charges with the charges+Q and -Q. Exactly in the middle of the two charges (distance r from both charges) is point P, colinear with the centers of both charges. A Gaussian surface that includes point P is drawn above.
Using Coulomb's Law, we can find the electric field at point P:
E=2*((1/4πε0)Q/r2)=(1/2πε0)Q/r2)
(since the electric field vectors caused by both charges have the same magnitude and add at point P)
However, if I try to use Gauss's Law to calculate the electric field at point P, I get:
E*4πr2=Qenclosed0, or
E=(1/4πε0)Q/r2)
(since the Gaussian surface is symmetric to the electric field, I simplified the surface integral to E*4πr2)
The two calculations differ! Can someone please clarify the error?!
Simple. The total field is not constant across the Gauss surface. You would really need to do the integral.
In other words, here is your error:
Not symmetric for the total field!
Note: Welcome to PF!
Likes davenn, Dale and shj
Oh alright. Thank you.
You're welcome!
The electric field is not spherically symmetric
Edit: oops, I am too late. Good job @Stavros Kiri
Likes shj and Stavros Kiri
