Apparent forces in circular motion
The discussion revolves around calculating the speed of a roller coaster car at the bottom of a dip, where passengers feel 50% heavier than their actual weight due to the forces in play. It is established that the normal force exceeds the weight, leading to the equation n = 1.50w. The net force acting on the car is identified as 0.5w, which serves as the centripetal force necessary for circular motion. Participants suggest using a free-body diagram and applying Newton's second law to solve for acceleration. The final calculated speed of the roller coaster car is confirmed to be 12 m/s.
lokobreed
The passengers in a roller coaster car feel 50% havier than their true weight as the car goes through a dip with a 30 m radius of curvature. What is the cars speed at the bottom of the dip?
I understand that there are two forces affecting the rollercoaster car - the normal force and the weight (mass x gravity)... Also since they feel 50% heavier the normal force must be greater than the weight. so n (normal force) > w (mass x gravity) thus the n = 1.50w.
So sum of force = n - w = 1.50 w - w after this I am completely lost... can anyone help please!
The net force you have correctly calculated as 0.5w is the centripetal force. Calculate v using the centripetal force equation .
Draw a free-body diagram of the roller coaster, label all forces, and write out Newton's second law for the vertical direction. What's the acceleration?
thank you
I got 12m/s
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
