What is the Total Profit Generated by a Machine in a Factory?
chrisyuen
The monthly cost C(t) at time t of operating a certain machine in a factory can be modeled by C(t) = aebt-1 (0 < t <= 36),
where t is in month and C(t) is in thousand dollars.
The following table shows the values of C(t) when t = 1, 2, 3, 4.
C(1) = 1.21; C(2) = 1.44; C(3) = 1.70; C(4) = 1.98.
(a)(i) Express ln[C(t)+1] as a linear function of t.
(a)(ii) Use the given table and the graph paper below to estimate graphically the values of a and b correct to 1 decimal place.
(a)(iii) Using the values of a and b found in (a)(ii), estimate the monthly cost of operating this machine when t = 36.
(b) The monthly income P(t) generated by this machine at time t can be modeled by P(t) = 439 - e0.2t (0 < t <= 36),
where t is in month and P(t) is in thousand dollars.
The factory will stop using this machine when the monthly cost of operation exceeds the monthly income.
(i) Find the value of t when the factory stops using this machine. Give the answer correct to the nearest integer.
(ii) What is the total profit generated by this machine? Give the answer correct to the nearest thousand dollars.
(Answers
(a)(i) ln a + bt
(a)(ii) a = 2.0, b = 0.1
(a)(iii) 72.1965 thousand dollars
(b)(i) 30
(b)(ii) 10806 thousand dollars)
Definite Integration Formulae
I don't know how to solve part (b)(ii).
\int^{29}_{0} (P(t) - C(t)) dt
=[440t - \frac{1}{0.2}e0.2t - \frac{2}{0.1}e0.1t]^{29}_{0}
=10770 (but not 10806)
From the answer you got in (b)(i) I would say you have to integrate from 0 to 30, this gives the correct answer to (b)(ii).
Yes, I got it!
Thank you very much!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
