How Does a Coaxial Cable's Capacitance Change with Different Configurations?
The discussion focuses on calculating the capacitance of a coaxial cable with two dielectrics and the effect of adding an ungrounded metal shell. The original capacitance formula needs modification to account for the two dielectric layers, requiring the derivation of electric fields and voltage differences. For the second problem involving a charged spherical shell above a grounded plate, the method of images simplifies the calculation by treating it as two oppositely charged spheres. Gauss's law is applied to find the electric field for each sphere, and superposition is used to determine the total field. The conversation highlights the challenges posed by the textbook's complexity and seeks additional resources for better understanding.
bdubb427
Help please w/ the following questions
A coaxial cable is given with two concentrically placed dielectrics. What is the capacitance of this structure? If an ungrounded metal shell is placed at a certain distance from the inner electrode, what will be the capacitance now? Plot the magnitude of field and potential as a function of radius in both cases.
C = Q / V = [2 * pi * epsilon * length] / [ln(b/a)] where b is the radius of the entire cable (outer and inner conductor) and a is the radius of just the inner conductor
2. A charged spherical shell is placed 1m above a ground metal plate. Find electric field.
besides coulomb's law, i don't have any other relevant equations for this.
Our textbook is really hard to understand, and the examples given in the text are even harder to follow. the book is Fundamentals of Applied Electromagnetics by Ulaby.. Any suggestions for another book are nice, but my exam is coming up and finding another book is just not an option at this point. Please help if u can. thank you...
For problem 1, you have four layers: a charged conducting cylinder, an inner dielectric layer, an outer dielectric layer, and an outer conducting shell. Because you have two dielectrics, the equation you provided (with just one epsilon) won't work. You'll need to rederive that expression for two dielectrics. I believe this would require a.) finding the electric field in the presence of a dielectric, which might be as simple as switching epsilon_0 with epsilon_1 in region 1 and epsilon_2 in region 2 (however you decide to label them); b.) calculating the voltage differences between the boundaries from the electric fields; and c.) calculating Q/V. I am not sure if adding in a thin metal shell would make any difference.
The second question seems much easier. First, with the method of images we know that this problem is equivalent to one where we have two spheres with opposite charges which are 2m apart. Gauss's law gives you the E-field for each sphere in the absence of the other sphere, and by the superposition principle you just add their fields to get the total.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
