MHB How Far Does a Bouncing Ball Travel Before Stopping?
A ball dropped from a height of 270 m rebounds to 10% of its previous height with each bounce. The total vertical distance traveled by the ball before coming to rest is calculated using a geometric series. The formula derived shows that the total distance is 330 m. This includes the initial drop and all subsequent rebounds. The calculations confirm that the answer of 330 m is correct.
Starkiller2301
Hi everybody, can you please help me with this question and with the working out?
A ball was dropped from a height of 270 m. On each rebound, it rose to 10% of the previous height. Find the total vertical distance traveled by the ball before coming to rest.
Thanks,
Starkiller2301
Mathematics news on Phys.org
Hello, Starkiller2301!
Let x = original height.
First, the ball falls x meters.
It bounces up \tfrac{x}{10} m, and falls \tfrac{x}{10} m.
It bounces up \tfrac{x}{10^2} m, and falls \tfrac{x}{10^2} m.
It bounces up \tfrac{x}{10^3}\,m, and falls \tfrac{x}{10^3}\,m.
And so on.Total distance:
\quad d \;=\;x + 2(\tfrac{x}{10}) + 2(\tfrac{x}{10^2}) + 2(\tfrac{x}{10^3}) \cdots
\quad d \;=\;x\left[1 + \tfrac{2}{10}\underbrace{\left(1 + \tfrac{1}{10} + \tfrac{1}{10^2} +\tfrac{1}{10^3} + \cdots \right)}_{\text{geometric series}} \right]
The geometric series has sum \frac{1}{1-\frac{1}{10}} \:=\: \frac{1}{\frac{9}{10}} \:=\:\frac{10}{9}
d\;=\;x\left[1 + \tfrac{2}{10}\left(\tfrac{10}{9}\right)\right] \;=\;\tfrac{11}{9}x
Therefore: \;d \;=\;\tfrac{11}{9}(270) \;=\;330\text{ m.}
Thanks so much! I had the answer sheet but I didn't know how to get the answer. 330m was correct!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
