MHB How Can You Measure an Irregularly Shaped Tunnel's Area Over Time?
  • Thread starter Thread starter Yankel
    Area
To measure the area of an irregularly shaped tunnel that changes over time, one can utilize the distance measurements between points along the tunnel to approximate its area. Since the tunnel lacks a defined geometric shape, traditional area formulas are not applicable. Instead, methods such as numerical integration or statistical approaches like Monte Carlo simulations can be considered for approximating the area based on measured widths at various points. Utilizing approximation methods for definite integrals can provide a practical solution for tracking changes in the tunnel's area over time. This approach allows for effective analysis of whether the tunnel is "shrinking" or not.
Yankel
Hello all
I have a tricky problem, maybe you can give me some ideas.
In the attached picture, there is a drawing of a shape, it is some sort of a tunnel, or channel.
This tunnel's area is varying in time, and I am looking for a way to measure it's area, so I can analyze the change over time. The problem is, it does not have a defined shape, not a geometric one, for area formulas, and not a functional one for the use of integrals or numerical evaluation of them.
What I CAN provide, is the distance between any two points in the tunnel. For instance, I can measure the length of the tunnel, approximately (!). I can also measure the width at any point, so basically I can measure the width at varying points, along the length (see arrows).
I am looking for a way to approximate the area of the tunnel, so I can know if it's "shrinking" or not. I was thinking maybe about statistical ways, like monte carlo simulation, but I am not sure I am even on the right direction here. Maybe you can give me some ideas for a practical measure ?
Thanks !
Mathematics news on Phys.org
If you know the width at any point, or set of discrete places, then you can use any of the approximation methods for definite integrals.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
