What is the arc-length parameterization for a given vector function?
In summary: It seems like the integral could not be zero, because the terms of the integrand are all positive. However, taking the natural log of both sides does work and yields { e }^{ 2t }+{ e }^{ -2t }={ 2sinh(2t)+1 }{ sinh(2t)}=0, which is the correct answer.
Sho Kano
372
Find the arc-length parameterization for [itex]r(t)=\left< { e }^{ 2t },{ e }^{ -2t },2\sqrt { 2 } t \right> ,t\ge 0[/itex]
[itex]s(t)=\int { \left| \dot { r } (t) \right| dt } [/itex]
[itex]\dot { r } (t)=\left< { 2e }^{ 2t },-2{ e }^{ -2t },2\sqrt { 2 } \right> \\ \left| \dot { r } (t) \right| =\sqrt { 4{ e }^{ 4t }+4{ e }^{ -4t }+8 } \\ =2\sqrt { { e }^{ 4t }+{ e }^{ -4t }+2 } \\ =2\sqrt { { e }^{ 4t }+\frac { 1 }{ { e }^{ 4t } } +2 } \\ =2\sqrt { \frac { { e }^{ 8t }+{ 2e }^{ 4t }+1 }{ { e }^{ 4t } } } =2\sqrt { \frac { \left( { e }^{ 4t }+1 \right) \left( { e }^{ 4t }+1 \right) }{ { e }^{ 4t } } } \\ =\frac { 2 }{ { e }^{ 2t } } \left( { e }^{ 4t }+1 \right) \\ ={ 2e }^{ 2t }+{ 2e }^{ -2t }\\ s(t)-s(0)=\int _{ 0 }^{ t }{ { 2e }^{ 2t }+{ 2e }^{ -2t }dt } =0[/itex] It can't equal 0...where did I go wrong?
It looks correct to me until the very last step where you say the integral is zero. The integral is not zero. It couldn't be, because both terms of the integrand are positive.
Note that ##2e^{2t}+2e^{-2t}## is ##2\cosh 2t##. Have a look at the graph of the cosh function and it will be immediately apparent that its definite integral from 0 to ##t## is positive.
Likes Sho Kano
Shoot, I made a mistake in the integration. It should be [itex]s(t)=2\int { { e }^{ 2t }+{ e }^{ -2t } } =2\left( \frac { { e }^{ 2t } }{ 2 } -\frac { { e }^{ -2t } }{ 2 } \right) [/itex]. That's obviously not zero.
What's the next step? Taking the natural log doesn't seem like it will work out, because I'd be left with [itex]{ e }^{ 4t }-1[/itex] inside the log. [itex]s={ e }^{ 2t }-{ e }^{ -2t }=\frac { { e }^{ 4t }-1 }{ { e }^{ 2t } } [/itex]
You could also put ##|\dot{r}(t)| = \sqrt{8} \sqrt{1+\cosh(4t)}##.
Likes Sho Kano
OK, this problem was a pain
[itex]s={ e }^{ 2t }-{ e }^{ -2t }=2sinh(2t)\\ \frac { s }{ 2 } =sinh(2t)\\ arcsinh\left( \frac { s }{ 2 } \right) =2t=ln\left[ \frac { s }{ 2 } +\sqrt { 1+\frac { { s }^{ 2 } }{ 2 } } \right] \\ r(t(s))[/itex]. So is it unsolvable without using hyperbolic functions?
What is Arc-Length Parameterization?
Arc-length parameterization is a method for representing a curve or path using its length as the independent variable. In this method, the curve is divided into small segments and the length of each segment is used as the parameter to describe the position along the curve.
Why is Arc-Length Parameterization useful in scientific research?
Arc-length parameterization is useful in scientific research because it allows for more accurate and precise measurements and analysis of curves and paths. It also makes it easier to compare and analyze different curves, as they are all standardized based on length rather than other variables.
What are the benefits of using Arc-Length Parameterization over other methods?
Arc-length parameterization has several benefits over other methods, including being more numerically stable and accurate, as well as being able to handle curves with varying curvatures and lengths. It also allows for easier integration and differentiation of curves.
How is Arc-Length Parameterization calculated?
The calculation of Arc-Length Parameterization involves dividing the curve into small segments, calculating the length of each segment, and then summing up these lengths to determine the total length of the curve. This total length is then used as the parameter to describe the position along the curve.
What are some applications of Arc-Length Parameterization in scientific research?
Arc-length parameterization is commonly used in fields such as computer graphics, robotics, and computer-aided design, where precise and accurate representation of curves and paths is essential. It is also used in physics, engineering, and mathematics for analysis and modeling of various phenomena and systems.
