B Archimedes' Principle for gases - derivation?
Archimedes' Principle applies to gases similarly to liquids, but the challenge lies in the compressibility of gases, which leads to varying density with height. The derivation for buoyant force in gases involves integrating the pressure difference across the height of the cylinder, accounting for the changing density. The pressure differential is expressed as dp = ρg dh, leading to a total pressure difference that correlates with the mass of the displaced gas. By stratifying the gas into thin layers, the average density can be treated as constant for each layer, simplifying the calculation of buoyant force. This understanding clarifies how buoyant force in gases equates to the weight of the displaced gas, despite density variations.
Amaterasu21
Hi all,
I understand where Archimedes' Principle comes from in liquids:
If we imagine a cylinder immersed in a liquid of density ρ whose cross-sectional area is A and whose top is at depth h1 and whose bottom is at depth h2:
Force(top of cylinder) FT = ρgh1A
Force(bottom of cylinder) FB = ρgh2A
Buoyant force = ρgA(h2-h1)
= ρA(h2-h1)g = ρVcylinderg = mdisplaced liquidg = weight of displaced liquid
therefore buoyant force = weight of displaced liquid.
I also understand that this works even if the object immersed in liquid isn't a cylinder because pressure at any depth is constant, so the horizontal components of pressure on any surface of the object cancel out, and the vertical components produce the same buoyant force as the cylinder.
But what I don't understand is why this is true for gases as well. I've been told that the buoyant force in gases is equal to the weight of displaced gas. However, gases unlike liquids are compressible and a large mass of gas in a gravitational field (e.g. the atmosphere) will be far denser at the bottom than at the top. Therefore while ρ is constant during the derivation for liquids, it would certainly NOT be constant across the height of the cylinder in a gas!
Force(top of cylinder) FT = ρ1gh1A
Force(bottom of cylinder) FB = ρ2gh2A
Buoyant force = gA(ρ2h2 - ρ1h1)
...and I don't see how we get from here to "= weight of displaced gas!"
Any help would be appreciated!
This is not correct, the pressure a priori not dependent on the density in the way you describe. What is true is that the pressure differential is given by ##dp = \rho g \,dh##. In the case where ##\rho## is constant, this implies that ##p = p_0 + \rho g h##, where ##h## is the vertical distance to some reference level where the pressure is ##p_0##.
The pressure force acting on your cylinder is given by the pressure difference between the top and bottom. This pressure difference is given by
\Delta p = \int_{h_1}^{h_2} dp = \int_{h_1}^{h_2} \rho g \, dh = g \int_{h_1}^{h_2} \rho\, dh.
If you have a cylinder with a cross-sectional area ##A##, this implies
\Delta p = g \int_{h_1} ^{h_2} A \rho \, dh = g M,
where ##M## is the mass of the displaced fluid (since it is the volume integral of the corresponding density).
Likes Amaterasu21
Thank you, this explains it! I should have realized we'd need to integrate since we're dealing with a constantly changing density with height.
Amaterasu21 said:
I've been told
Were you given any reference for this information? I appreciate that you may have reservations because it looks 'too simple'.
If you stratify your volume into sufficiently shallow layers to consider the density to be constant over the thickness and equal to the mean value then the buoyant force for that slice would in fact be the weight of the slice displaced. IMO, that should be sufficient.
It should be pointed out that, in essence, this is nothing but the typical Riemann sum, which in the end results in the integral outlined in #2.
Likes sophiecentaur
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
