What is Archimedes' Principle?
In summary, Archimedes' principle states that the buoyant force acting on an object immersed in a fluid is equal to the weight of the fluid displaced by the object. The volume of fluid displaced is equal to the volume of the submerged part of the object. If the buoyant force is greater than the weight of the object, it will float, and if it is less, it will sink. The mass of the displaced water is equal to the mass of the object when it is floating, but less than the mass of the object when it sinks. This is because the volume of the object underwater is the same in both cases, but the density of the object is higher when it sinks. Therefore, the mass of the displaced water must
Drizzy
210
Can somebody please tell me exactly what archimedes prnciple is?
[/B]
So, I watched this video: . Apparently if we have a cube in a bucket of water then the mass of the whole cube is equal to the mass of the displaced water. So that means if the cube and the water has the same mass (and obviously the have different density) then the volume of the displaced water is equal to the volue of the cube that is under the water.
Is it correct?
Yes? (If you mean what I think you mean)
The statement of Arch.P. in the video is correct.
The buoyant force is equal to the weight of liquid displaced.
The volume of liquid displaced is equal to the volume of the submerged part of the object.
The mass of liquid displaced is equal to the volume x density.
The weight of liquid displaced (and hence the buoyant force) is equal to the mass x g.
If buoyant force is greater than the weight of the object, it floats.
If buoyant force is less than weight of object, it sinks.
So basically the mass of the liquid is the cubes mass? right?
If the cube is floating, then the mass of the cube is equal to the mass of water displaced.
If the cube sinks to the bottom, then its mass is more than the mass of water displaced.
Why is that?
Is t because the cube and the displaced water have the same volume but if the cube sinks then it has higher density. so with the same volume and higher density then the mass needs to be higher
The amount of water displaced is equal to the volume of block underwater.
When the block floats, the part underwater is displacing water and the mass displaced is equal to the mass of the whole block.
When the block sinks, the whole block is displacing water, but the mass of water displaced is less than the mass of the block. So the buoyant force on the block is less than the force of gravity on the block and it sinks.
The important point to remember is, the upward force is equal to the weight of water displaced. And the amount of water displaced is the volume of block under water.
And to second Q, yes.
What is Archimedes' principle?
Archimedes' principle is a scientific law that states that the buoyant force on an object submerged in a fluid is equal to the weight of the fluid that the object displaces.
Who discovered Archimedes' principle?
Archimedes' principle was discovered by the ancient Greek mathematician and scientist, Archimedes of Syracuse, in the 3rd century BC.
How is Archimedes' principle used in everyday life?
Archimedes' principle is used in various everyday applications, such as determining the density of objects, designing ships and submarines, and understanding the behavior of hot air balloons.
What is the equation for Archimedes' principle?
The equation for Archimedes' principle is FB = ρVg, where FB is the buoyant force, ρ is the density of the fluid, V is the volume of the fluid displaced, and g is the acceleration due to gravity.
Is Archimedes' principle always true?
Yes, Archimedes' principle is a fundamental law of physics and is always true as long as the object is fully or partially submerged in a fluid and the fluid does not undergo compression or expansion.
  • Classical Physics
