Are Integral Equations Essential for Understanding Physics?
  • Thread starter Thread starter pantheid
    Course Integral
The discussion revolves around the relevance and utility of integral equations in the field of physics, particularly in the context of a graduate-level course being offered. Participants explore the mathematical foundations of integral equations, their applications, and their relationship to differential equations.
  • One participant expresses uncertainty about the usefulness of integral equations in physics, noting a lack of familiarity with them.
  • Another participant questions the necessity of a full course on integral equations, citing a lack of prior offerings.
  • Several participants inquire about the course content, indicating a desire for more information.
  • A participant highlights that integral equations are foundational to the boundary element method (BEM), which is used in various fields such as acoustics and electromagnetics, suggesting that knowledge of these equations is beneficial for graduate physicists.
  • It is mentioned that the simple RLC series circuit can be modeled using an integro-differential equation.
  • One participant discusses the two approaches to constructing mathematical models: using differential equations to analyze behavior at each point and using integral equations to consider properties over a region, noting the advantages and limitations of each method.
  • Another participant clarifies that integral equations are not simply the opposite of differential equations, explaining that solving integral equations often involves converting them to differential equations.
Participants express differing views on the significance and utility of integral equations in physics. While some see them as essential for certain applications, others question their overall importance and the need for dedicated coursework.
Participants express uncertainty regarding the course content and the specific applications of integral equations, indicating that the discussion is limited by the lack of detailed information about the course and the varying levels of familiarity with the topic.
pantheid
Hi all, my university is offering a graduate level math course in integral equations for the following semester. I'm not at all familiar with them (I'm assuming they're the opposite of differential equations?), and I'm wondering if you guys think they are at all useful in the field of physics, because I don't recall ever coming across one but it seems like something that could be important.
I didn't think there was much there to offer a full course in it. I have never heard it offered as a course before.
Can you give us the course contents?
Unfortunately, no. The only description is that the course content varies.
Then I guess you should talk to the professor who teaches the course.
I like the way you think, but I also just wanted to see if you guys ever use integral equations in your work.
Integral equations form the mathematical basis for the boundary element method (BEM), which itself grew out of work done in adapting the finite element method (FEM) to the solution of partial differential equations (PDE), like the Laplace, Poisson, and Helmholtz equations. BEMs are useful not only for the solution of problems involving stress and strain, but they have been useful for many years in solving complicated acoustic, aerodynamic, hydrodynamic and electro-magnetic problems. A graduate physicist who plans to work in any of these fields should be familiar with PDEs and integral equations, if for no other reason, to be familiar with how these types of problems are analyzed and solved.
http://en.wikipedia.org/wiki/Integral_equation
http://urbana.mie.uc.edu/yliu/Research/BEM_Introduction.pdf
the simple RLC series circuit is modeled by an integro-differential equation.
Leaving the details (and the "sales and marketing" arguments made by some enthusiasts for one method in preference to another!) I think the basic point is that there are two ways to construct a mathematical model. One is to consider the behavior of the system at each point, which often leads to an ordinary or partial differential equation. The other way is to consider some properties of a finite (or infinite) part of the system, which often leads to an equation involving integrals.
The advantage of the integral equation approach (when it works - for example it often works better for linear problems than nonlinear ones, as SteamKing's list of BEM applications shows) is that the "dimension" of the solution is often reduced by one, i.e. the solution for the whole region is expressed in terms of the behavior on its boundary. That has obvious advantages if the region in infimite. It can also have disadvantages, if trying to express the solution in terms of the boundary is ill-conditioned for physical reasons, independent of the cleverness of the math (for example the transient behavior of a system after the boundary conditions change from one constant state to a different constant state).
I would say integral equations and the numerical methods derived from them have more limited general utility than differential equations, but they are certainly useful for the right type of problems, as well as being interesting mathematics independent of particular applications.
I would not say that "integral equations" are the opposite of "differential equations"! In fact, a standard method of solving integral equations is converting to a corresponding differential equation. And theoretical concepts in differential equations, such as showing that dy/dx=F(x,y), y(x_0)= y_0 has a unique solution, can be done by converting to integral equations. (That's because, while the space of all differentiable functions is NOT closed under the operation of differentiation while the space of all integrable functions IS closed under the operation of integration.)
  • · Replies 40 ·
  • · Replies 43 ·
