Does Combining Lumens Make a Difference?
  • Thread starter Thread starter mattloto
Combining lumens from multiple light sources does result in an additive effect, meaning two bulbs producing 1,000 lumens each will equal 2,000 lumens total. However, when considering brightness, it’s essential to account for the spectral sensitivity of human vision, as different light sources with the same wattage can produce varying lumen outputs. The measurement of brightness on a surface, such as a wall, will depend on the light source’s characteristics and the lens used. Understanding the units of visible radiation, including lumens and watts, is crucial for accurate communication and assessment of light output. Overall, while lumens do combine, the specific characteristics of each light source must be considered for precise measurements.
mattloto
I've looked for this answer around the web, and I've gotten mixed results, so I'm asking here. If I have 2 light bulbs that produce 1k lumens each, will it be the same as 1 light bulb producing 2k lumens?
And on the topic, if I have a light source and I put a lens between it and a wall, what measurement will tell me how bright the image will be when it hits the wall. Thanks!
I believe that they do add with each other.
mattloto, get yourself educated in the units of visible radiation. Actually, there are a lot of them, some derived, like the lumen. Once you have the definitions down correctly you can always communicate with others accurately. You might start here:
http://en.wikipedia.org/wiki/Lumen_(unit )
Lumens are a photometric version of radiant flux, the radiometric units are Watts. Because flux (power) is an integrated quantity, it does not have any directional dependence. So yes, the lumens will add.
However, because 'lumens' takes into account the spectral sensitivity of vision, you have to be careful when converting watts to lumens- two identical wattage bulbs, if the spectral output is different, will have different lumens.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
