Are My Test Review Answers Correct?
  • Thread starter Thread starter iirevolverii
    Review Test
The user is seeking validation for their answers on a test review, specifically for four problems, and has shared images of their work. They realized they needed to convert grams to kilograms for questions 2 and 3, which significantly altered their results. After making the conversions, they reported new values for these problems, including a velocity of 673 m/s, which they believe is more reasonable than their initial answer of 22 m/s. The user is asking for feedback on their revised calculations and overall accuracy. They express appreciation for any assistance provided.
iirevolverii
Hey hows everyone doing, this is the first time I am posting HW.
I need help with 4 problems which are from my test review.
Attached are scan images of the test review sheet with solved answers.
I need to know if I have done this right. Thanks.
On image.
On image.
On image.
Youll have to fix the links. When you see the image, just right click and save on desktop to preview in small version, because the image is big. Thanks.
www.imghost.cc/files/1b9puskkr5mofc56qvh8.jpg[/URL]
[PLAIN]www.imghost.cc/files/4d755578ezxik4w2kf8g.jpg[/URL]
thanks for fix the links..
Someone please check over my work.
I did notice for question numbers 2 and 3, i forgot to convert the grams to kilograms.
Once I go home from work, will sovle them with the converted numbers.
On problem #3 you need to convert the mass to kilograms when calculating the mass-per-unit-length in the velocity equation.
Your numbers will turn out more reasonable. 22 m/s on a short string seems a bit much :p
I just did that and what i got for velocity was 673 m/s.. this is way more than the previous answer of 22 m/s.
After converting the grams to kilograms.. this is what i got for problem #'s 2 and 3.
2) A = 0.146 m
t = 0.160 s
3) v = 673 m/s
wavelgenth = 3.00 m
f1 = 224 hz
f3 = 673 hz
Did I do the rest correctly?
I just redid problems 2 and 3 with the correct conversions.
You will have to fix the links, it won't let me because I don't have 15 posts.
vvww.imghost.cc/files/l2mjf2aws0n63fafwxbm.jpg
vvww.imghost.cc/files/377doh319isr7usmkatz.jpg
Can anyone please check over my work.. I need to know if what I studied is right.
I will greatly appreciate it.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
