Are these two resistors in Parallel?
  • Thread starter Thread starter jwllorens
    Parallel Resistors
The discussion revolves around the configuration of resistors in a circuit and whether two specific resistors can be considered in parallel. Participants explore how to calculate the equivalent resistance of the circuit between two points, A and B, and discuss potential simplifications and methods for analysis.
  • One participant describes a circuit diagram and asks if the two green resistors are in parallel, suggesting they can be reduced using the formula (Ra*Rb)/(Ra+Rb).
  • Another participant agrees that if the tops and bottoms of the green resistors are connected by wires, they are indeed in parallel.
  • A later reply confirms the previous agreement but notes that the diagram was difficult to read, emphasizing the importance of visual clarity.
  • One participant suggests that the circuit can be simplified to a diamond shape with a resistor in the middle, where Kirchhoff's equations could be applied.
  • Another participant mentions that there may be additional simplifications based on resistor values and symmetries, and that Kirchhoff's laws or other techniques could be used for further analysis.
  • One participant cautions against the term "irreducible," suggesting that there are established equations for simple circuits and mentions the Delta-Y conversion as a method for further simplification.
Participants generally agree that the two green resistors can be considered in parallel if connected appropriately, but there is no consensus on the terminology used to describe the circuit's reducibility or the specific methods for analysis.
The discussion includes assumptions about the circuit's configuration based on a potentially unclear diagram. The applicability of Kirchhoff's laws and the potential for simplifications depend on the specific values of the resistors and the circuit's geometry.
jwllorens
Say I have a circuit that looks like this:
..._______
B___|_|_|_|___ A
The red and green lines are resistors.
The black lines are wires.
Assume a connection between any component line that is at a right angle to any other line, and a current source applied to points A and B.My question is this: Are the two green resistors in parallel, and thus, can I reduce them to a single resistor using (Ra*Rb)/(Ra+Rb)?
If not, any suggestions on how to calculate the equivalent resistance of this entire circuit, between points A and B?
..._______
B___|_|_|_|___ A
Welcome to the PF.
It's a little hard to read the diagram, but if there are just wires connecting the tops and bottoms of the two green resistors, then yes, they are in parallel.
Welcome to the PF.
I had to magnify the page to really see the diagram but they ARE black (lines) so your explanation is correct.
great, thank you. So the whole thing can be reduced to a diamond shaped circuit with a resistor in the middle, which becomes an irreducible circuit, at which point kirkoffs equations can be applied?
There may be other simplifications, depending on the values of the resistors (like if there are symmetries). But in general yes, you would use KCL or some other technique to work on the circuit at that point.
Irreducible is a bit strong, since simple circuits like that have been done and have equations you can look up. Google "Delta-Y conversion" to see what I mean. You have a delta and want a Y and then you can go from there.
These conversion were done USING kirchhoff analysis, so of course you CAN just do that.
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 21 ·
