ABHoT
- 33
- 0
Are waves only 'waves' if you try and represent them in 2D? If an object emits waves in all directions are the waves more like expanding spheres?
If a wave/sphere hits us and the source is sufficiently far away (and strong?) do we 'experience' it as though being hit by a plane? or multiple repeating planes, where the planes are more dense in the wave peaks and lesser in the troughs?
Does wavelength refer to how narrow the distance between peaks & troughs are and is there a separate description for signal strength? Does it spread out like light photons do, over distance? (have I just described the same thing?)
What about more directional emitters, would they be the same, only the planes are more local as it where?
Can/do multiple waves of different wavelengths be hitting us at the same time? Is this because they can share the same quantum state?
Given a sphere of #unlimited light sources shining inwards into a limited space, is there a limit to how many photons can occupy the same physical location?
Are wavelength and speed independant? 20 questions, apologies feeling really enthusiastic.
On the contrary, it's good to see your enthusiasm, and it is very commendable that you want to learn. I've just been through this process many times as I learn new things. You eventually learn the most efficient process to get the fundamentals down, and then incrementally work through the various conceptual sticking points by talking to others that have already been through the process.
